VOLK RE30 on EVO X
No it is a customers car lent to me for a full track suspension system (done and ready for sale)
KW Varient 3 double adjustable suspension. swaybar endlinks front roll center bumpsteer and front swaybar mounting points
whats up robi its brandon (06MR) with those wheels you said spacers are needed. Do you also need extended studs??
and do you have any other shots with the wheels on the car??
So the Evo X needs to run staggered wheel set ups? What if you're looking to 18x9.5 all around. Whats the lowest offset you think that would work with a 255-275 tire?
I should clear something up here in order to MAXIMIZE tire size we will be playing around with the offsets front to rear to land the tire exactly under the sheet metal. a 275 35 18 on a 9.5" wheel with an offset range of +40 to +30 WITH THE FRONT CALIPER/SPOKE CLEARANCE seems to be the sweet spot. it wont look super aggressive because the tire will still be inboard of the max stance (or track)
