Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Advan rs
Old Jan 29, 2009 | 08:16 PM
Silver06evo9mr's Avatar
Advan rs
looking to get 19x10 advan rs rims
what offset (35,25,15 are the choices) and tire size do i need to go with and what kind of fender rolling am i going to need?
Old Jan 29, 2009 | 08:55 PM
joowick's Avatar
Evo 9? Evo X?
Old Jan 29, 2009 | 09:02 PM
beetle_orange's Avatar
if you go with a +35 you MIGHT get away with a 275/30 without any fender work.
Old Jan 30, 2009 | 06:50 AM
Originally Posted by joowick
Evo 9? Evo X?
this is the X sections isnt it?? yes evo X
Old Jan 30, 2009 | 06:51 AM
im not too knowledgeable on offsets, cam someone explain the differecen between the three?
Old Jan 30, 2009 | 03:25 PM
i8fizh's Avatar
The smaller the offset the farther out the wheel sits from the hub. The number is in mm. +35 will probably rub on the strut, where as the +15 will stick out of the wheel well and rub on the fender.
Google an offset calculator and compare.....stock is 8.5 +38mm
Old Jan 30, 2009 | 05:46 PM
so if this is true ^^ +25 would be the best bet for a nice median
Old Jan 30, 2009 | 10:25 PM
CatalystGod's Avatar
the definition of offset is that its the distance from the hub-mounting inner surface of the wheel to its center on the wheel rim. The following link at tire rack will help you.
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old Jan 30, 2009 | 10:26 PM
Use this for calculation
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jan 31, 2009 | 07:00 AM
well with 19x10 either way im gunna need to do some fender rolling im sure right?
Old Jan 31, 2009 | 08:54 AM
BlackTrack's Avatar
Depending on tire size, most likely. If you are gonna roll them anyways, might as well go for the +15
Old Jan 31, 2009 | 06:15 PM
what about the spring pearch? will they rub on there?
Old Jan 31, 2009 | 06:17 PM
BlackTrack's Avatar
No.
