Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Stock KWs vs Robi Spec'd KWs
Old May 12, 2009, 10:08 PM
jimm's Avatar
Wondering if anyone here has compaired the stock KWs to Robi spec'd. Thinking of sending him mine and buying his rollbar and set up.
Old May 14, 2009, 10:03 PM
Mad Villain's Avatar
I have the robi spec streets v3's and his rear sway bar, I love it.
Old May 15, 2009, 09:41 AM
jimm's Avatar
Thanks for the reply (I know there is more than this that have this setup (please comment guys)
You guys in Cali have pretty smooth roads don't you? I was wondering 1) how it compares to the OEM GSR set up 2) how it functions as a DD and 3) how the set up compares on track/autocross.
Old May 25, 2009, 12:04 PM
IX2X's Avatar
Robispec KW's
I have Robispec KW clubsports on my X
Also purchased from Robi:
Front roll center kit
Rear sway bar 26mm
Enkei NT03+M 9.5X18+40
Nitto NT05's purchased elsewhere.
Aligned and corner balanced...
Two words: Totally awesome!
I'll be posting up my critique once I have a chance to run them in autoX or on the track!
Old May 25, 2009, 12:38 PM
Evo_Someday's Avatar
I believe the Robi Spec ones use different springs (On the EVO 8/9 it was something like 8k front 9k rear - though he could use whatever you wanted - as opposed to the 9K front and 6K rears the KWs come with) and custom valving to account for the different springs.
Most trackers and autocrossers will tell you that you need the stiffer springs in the rear to help the car rotate. But most coilover companies will put the stiffer springs in the front to induce understeer to keep it "safe".
There is no doubt that the Robi versions would be better setup for track and/or autocross than the stock KWs. As for daily driving, plenty of people dd on coilovers with equally stiff springs. Compared to OEM I'm sure youll notice they are stiffer but if the roads are pretty smooth where you are, it should be too much of an issue.
Old May 25, 2009, 09:21 PM
GTWORX.com's Avatar
I'd argue that a lot of coilover companies put stiffer spring up front on the EVO because they're clueless or simply not trying.
Luckily, KW did get the rates down fairly well for the X. My advice is to definitely consider support after the sale with whatever coilover you get....Robi gets points there for sure.
- Andrew
Old May 25, 2009, 10:34 PM
Cyp
Cyp's Avatar
original question is good becuase you can pickup a set of KW V3 for the X for about $1900. Whereas Robi's are $2400. That's quite a bump in price. So I too am wondering whether or not its worth the extra $500. Why can't KW make a similar setup?
Old May 25, 2009, 10:35 PM
Cyp
Cyp's Avatar
Rear sway bar 26mm
Is the clubsport stiffer than the street version? If so, by how much? Which front roll center kit did you purchase?
Old May 26, 2009, 06:35 AM
GTWORX.com's Avatar
Where do you see them for that price?
Old May 26, 2009, 11:06 AM
jimm's Avatar
I have been quoted KWs for a little less than that on this site by at least 2 different venders.
Question...has anyone compared the streets to the clubsports?
Old May 26, 2009, 11:08 AM
jimm's Avatar
The advantage that you are supposed to get with the KWs in general and specifically the Robisports after revalving is a better fast rebound for DD purposes. Anyfeel for the advantage?
Old May 27, 2009, 07:43 PM
evo003's Avatar
i believe robispecs are 7K front/ 8K rear for the streets. Regular KW's come 9K front and 6K rear if I'm not mistaken.
Old May 27, 2009, 08:17 PM
abu
abu's Avatar
Can anyone confirm a rumor i heard where there are 2 versions from KW for our cars? The part #'s are supposedly different.
Old May 27, 2009, 08:44 PM
evox44's Avatar
There is Street, Club and the $8000 Race. So depends. I am thinking of selling my KW's and going w/ Hipermax III sports,
Old May 27, 2009, 08:47 PM
abu
abu's Avatar
I meant that there are 2 versions of the V3s. Anyone know?
Quick Reply: Stock KWs vs Robi Spec'd KWs
