So who here has Robispec KW Race coilovers?
I ask because I just sent Mr. Spec a deposit for a set along with his advanced suspension package.
Has it changed your driving style? How have your lap times changed? How forgiving is it at the limit? What kind of tires are you running with it?
I have his whole package. Honestly it was a bit aggressive for street use so I softened up the bump quite a bit for dd purposes. Have not tracked it yet but spirited driving has the car quite a bit more positive on turn in. If you are some one who trail brakes a lot it you might need to put a little more grip back in the rear. I tend to induce a little understeer on entry so any thing that takes away push is good for me as long as I can get on the power early. In my experience, you just need a good solid starting point which you have with either robi's setup or really even the stock setup. From there you can probably get the car to behave what is naturally quick for you.
The benefit from robi's setup is you get matched and balanced coilovers with track proven sway, roll center and bumpsteer correction ... The rest is just tuning.
i had a KW V3. I was running very low. I sadly cant recall, but i think over 2 inch all around. but the car runned just great. The KW V3 has a "long " travel even when they dropped.
I used the Toyo R888's.
It is a very good riding quality coilover .
I liked them for road race.
here is my wheel alignment what i had. I think it was great.
What are you running now?
stock coilovers. I'm waiting my custom AMR Engeneering coilovers . Willl be here and installed hope fully before august.
http://www.amrengineering.com/
I'm running at a moment , Speedline Corse rims and Toyo R1R.
http://www.speedlinecorse.co.uk/
Wheel manufacturer will stay a same, but the tire type will change.
Also my gravel rims are coming
Whit the wheels my dream came true. I always wanted them, and finally i got them.
It's a pretty new application for the X, and mine turned out to be a little short for me since I wanted to increase ride height over stock. Andy at AMR took my dimensions and is making up some longer lower bodies. But they're perfect for stock or lower heights.
-- Bill
