Question on adjusting coilovers
How does this work? How much time does it take? Guessing it depends on the manufacturer?
I'm really just interested in reducing wheel gap, but I don't want to sacrifice too much comfort. I had an s2000 lowered on eibach springs and after a while it got to be too much for a daily driver.
Wondering about coilovers because I don't have a spring compressor and would be paying for a spring install, whereas I would be comfortable doing a full coilover install myself. Figured I could put the money saved on the install into some coilovers, but that depends on how difficult it is to make the adjustments and what I need to know to make them.
Is a "set it and forget it" mentality approriate for adjustable coilovers, or do I need to constantly adjust?
A set it and forget it mentality is very much appropriate. A lot of brands out there advertise 32 clicks of adjustment, but in reality, 30 of those clicks suck and 2 of them are just okay.
For a good coilover with good valving, you'll most likely leave it on 1 setting, sometimes adjusting it at the track.
- Andrew
- Andrew
Good point. Hadn't thought of that. What's entailed in that? Imagine you have to jack it up, remove the wheels? Any kind of measurement, or just count the clicks?
Ride height you jack up the car and use the spanner wrench that comes with your coilvoers to adjust the spring perches. Repeat as necessary to get the height you want. But then you need an alignment. Alignment is something you'll be going to a shop for and paying money. Changing ride height all the time is not recommended unless you have the time and money to do it often. Plan on 100 to 200 per alignment. So yeah, don't change your ride height all the time.
For damping, you usually just pop the hood and turn a knob.
Since your new to coilovers, I would highly highly recommend getting them from a suspension shop that knows a thing or two about suspension and can help you set them up correctly.
The alternative is to get some springs that don't suck (meaning springs that don't lower the car too much). Get some swaybars and call it a day.
- Andrew
- Andrew
With that in mind, I think the set and forget it mentality does work for most people.
If you have to constantly adjust the coilover, you have either bought a set of KW V3's with the fixed high speed valving, or you bought an awful coilover system.
cuscoevo
Jul 25, 2016 03:23 PM
jimm
Aug 21, 2015 08:32 AM
fromWRXtoEVO
33
Feb 25, 2014 03:59 PM
project_lancer
47
May 19, 2013 03:18 AM
Noize
61
Mar 7, 2012 08:26 AM
