One tire ruined, need to replace all 4?
So I acquired a gash in the sidewall of one of my front tires and its ruined (don't ask, bad day). Anyway, I have about 5k miles on tires (Direzza Star Specs) and I'm wondering if I need to replace the other 3 tires when I replace this one? I've heard that all wheel drive cars need to have all tires with equal wear, but obviously not super excited about buying a set of 4 when the other 3 tires still have at least 10k miles left on them.
+1 on the tirerack, they can easily shave it for you and ship it out.
Just gotta check the tread depth on the other tires
other option is to look for a speedshop, they will shave tires
Great, I was planning on ordering from TireRack anyway, so I'll just measure the tread depth of the other front tire and get them to shave it a bit.
Thanks for the feedback, this is a relief, the thought of dropping $900+ on a set of new tires + mounting was kinda ruining my day.
wtf only 5k on your tires, you don't need to shave it or anything. just buy 1 tire and call it a day. a couple mm of tread depth differences isnt going to do anything to your transmission or differentials as long as you service it at the normal times. You realize that probably 60% of people on these boards dont rotate their tires at the proper intervals and that the difference between front and rear tires after 5-8k is about the same right? most if not all of the stories of people's diff's going out is because of launching and abuse.
If i'm wrong someone please correct me. It would be ludicrous to think that a car requires ALL tires to be at the SAME EXACT tread level at ALL times. we'd need to rotate our tires every 100 miles for that to happen.
also heres another thing to think about... what about uneven wear on a tire? how many people have had their diff's worn prematurely because they had obscene camber wear on one tire and NONE on the other? having extreme camber wear on 1 tire will also differentiate the the height of the tires from left to right.
If the tires are virtually new I doubt it would make much of a difference to just slap on another new tire. If there is noticeable wear on the other tires... then maybe you can get the new one shaved as others have said.
Also for people's info, for piece of mind, especially since he's ordering from Tirerack....i think it only costs like $40 bucks for them to shave it, thats worth the worry in the end
And really the amount of miles don't mean much, it really is all about how much tread depth is left....
for the OP, make you sure have a decent amount of tread depth otherwise for costs sake, it might make more sense to have four new ones.
Firebalz
15
Apr 15, 2011 06:48 AM
black_evo
52
Sep 17, 2007 01:03 AM
JTB
33
Feb 27, 2005 10:37 AM
