Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
suspension help
Old Mar 6, 2013 | 11:24 PM
dingelingyi's Avatar
suspension help
i heard metal to metal contact after i drove over a speed bump today. it kept clunking the entire way home and i put it on my jacks found that one of the screw is missing on my shock. i think the pressure in the shock is gone because i can easily move the wheel up and down. is this a simple fix or i have to take it off and service it at bilstein.
Old Mar 7, 2013 | 06:35 PM
Iowa999's Avatar
That's where the shaft the shock connects to the casing. That corner currently has no shock, which is a very bad thing on a car with struts, to say the least. Drive gently - if at all - to a place that can pull the strut apart and fix it or replace it.
It's simple if you've done it before. Don't do it unless you or a helper has done this before.
Krakker
Outlander Sport
22
Apr 25, 2014 02:05 PM
Nyaim
14
Mar 4, 2014 05:18 PM
Nyaim
Feb 25, 2014 03:50 PM
Stealth Ag
May 27, 2013 01:40 AM
