Hotchkis Rear Sway Bar and Endlink Review
This is my review of the Hotchkis Rear Sway Bar and the Hotchkis Heavy Duty Rear End Links.
Bar Diameter: 32mm
Sway Bar Type: Hollow
Adjustable: 3-Way
The Hotchkis rear sway bar is massive in diameter compared to our oem rear sway bar. The bar came neatly packaged, securing the sway bar with expanding foam. The sway bar included the mounts,bolts, washers, bushings, grease, instructions, and a checksheet for all the parts. Unfortunately, I was not able to weight the bar and parts.
I purchased the Hotchkis over the Whiteline due to the following reasons:
1) Past Experience
2) Price
3) Hotchkis is local to me (Free Will Call)
4) Bushing stay rings are welded onto the sway bar
Heavy Duty Endlinks
Configuration: Heim Joint
Adjustable: Yes
These endlinks are definitely more expensive then the competitors but there is a reason for it. The endlinks themselves are constructed of two Heim Joint Rod Ends. They came neatly packaged with all necessary materials. I'll let the pictures do the explaining for this part.
Overall Impression:
Installation was fairly straight forward for the sway bar. The only minor issue I had was that I had to remove the exhaust heat shield underneath the trunk to fit the sway bar. I have had no issues with unusual noises, binding, or clunking (I pre-loaded the suspension before tightening down the end links bolts to the sway bar and the control arm.)
The rear feels notably stiffer but I have only been driving on the street back and forth to work. Overall, I am very happy with the build quality of the bar and endlinks. I have had great past experiences with my hotchkis parts and their customer service ( I sheared a sway bar bracket and they replaced it very quickly for free). The price is the only con I can think of.
I'll update the post once I get some track time later this year.
Pictures:
Bar Diameter: 32mm
Adjustable: 3-Way
1) Past Experience
2) Price
Heavy Duty Endlinks
Adjustable: Yes
Overall Impression:
Pictures:
Daver403 (Apr 24, 2019)
I know it's an old thread... but I just bought the exact same Hotchkis sway bar and end links and measured the weights. Here are the numbers if anyone is interested (rounded to the nearest 5 grams):
End links including bolts and nuts
- Stock: 480g
- Hotchkis: 455g
Sway bar
- Stock: 3950g + 290g brackets
- Hotchkis: 5200g + 450g brackets
- Stock: 480g
- Hotchkis: 455g
Sway bar
What trim is your car
Hi was wondering what trim level your car is that you put this sway bar on ? I have a 2015 Se and I can’t find a sway bar in the rear? Thanks
Bar Diameter: 32mm
Adjustable: 3-Way
1) Past Experience
2) Price
Heavy Duty Endlinks
Adjustable: Yes
Overall Impression:
Pictures:
Attachment 271999
Attachment 272000
Attachment 272001
Attachment 272002
Attachment 272003
Attachment 272004
Attachment 272004
Attachment 272005
Attachment 272006
Attachment 272007
Attachment 272008
Attachment 272009
Attachment 272010
Bar Diameter: 32mm
Adjustable: 3-Way
1) Past Experience
2) Price
Heavy Duty Endlinks
Adjustable: Yes
Overall Impression:
Pictures:
Attachment 271999
Attachment 272000
Attachment 272001
Attachment 272002
Attachment 272003
Attachment 272004
Attachment 272004
Attachment 272005
Attachment 272006
Attachment 272007
Attachment 272008
Attachment 272009
Attachment 272010
MisUnderStood
20
Jan 18, 2016 05:57 PM
ak47m203
19
Mar 6, 2013 07:20 AM
titaniumkingpin
18
Jan 12, 2013 09:26 PM
Spun Autosports
Evo 'For Sale' Suspension / Brakes / Handling
20
Dec 3, 2007 05:29 AM
Luke WL.
May 31, 2006 11:17 AM
