Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Enkei RS05RR rims tire size recommendation.
Old Jul 28, 2018, 12:41 PM
KillaYayo's Avatar
whats up guys. I currently have Enkei RS05RR 18x9.5 / 5x114.3 / +22 (Face M) rims on my Evo X (got this especific one because it clears the brembos). I have looked up forums and see that people use 265/35/18 for these rims so i went with that and it fits perfect. Issue I’m having is that i have tire letterings in my tires and due to them being meatier tires the tires seem to rub against the back of the fender lining and it has messed up my tire lettering, does anyone know another size tires that may work with these rim’s specs. Thank you.
Old Jul 29, 2018, 01:08 PM
LetsGetThisDone's Avatar
Received 1,542 Likes on 1,321 Posts
Just roll the rear fenders.
Old Aug 2, 2018, 05:08 PM
KillaYayo's Avatar
its not the rear tires rubbing, it’s the front ones to the back of the fender liner not the actual fender.
Old Aug 5, 2018, 01:23 AM
Use a heat gun to warm the fender liner up, and push it back out of the way.
Old Aug 5, 2018, 08:56 AM
KillaYayo's Avatar
that actually sounds like a great idea... thank you so much.
Old Aug 8, 2018, 02:16 PM
1fastmf's Avatar
I have 18 x 9.5 +22, but went with cheap Rotas.
The 4 variables in this....and people rarely state more than 2 are:
1. Suspension, stock or otherwise.
2. Alignment, stock or crazy Civic look.
3. Tire size.
4. Tire brand. Check out the MFG stats. Section width varies between companies and models. Milimeters matter here.
I've had 275/35 since 2013. First on Dunlop Direzza II, and now on P-Zero Runflats. Only notice rear rub on heavy bumps with a big load in the trunk. Only hit front inner fenders at full lock for the first 3 months. Now the clearance is rubbed in by the tires. Zero other issues. Key is that I have stock suspension and alignment.
Its a great set-up.
Old Aug 9, 2018, 08:47 AM
KillaYayo's Avatar
3. Tire size.
Its a great set-up.
Cool, i have BC racing suspension and it’s lowered just to cover the wheel gaps. The reason the tires rub against the fender liner is because of the meaty tires which are 265/35/18. Someone suggested to heat up the fender liners and push them in so i will try that.
tigermack
For Sale - Wheels / Tires
21
Nov 8, 2015 09:38 PM
wickedevox_hpatel
Sep 1, 2015 06:30 AM
rosevol
Nov 15, 2014 07:18 AM
WarmMilk
23
Oct 10, 2014 01:51 PM
MODDICTION
Evo 'For Sale' Wheels / Tires
14
Jul 31, 2014 01:15 PM
Quick Reply: Enkei RS05RR rims tire size recommendation.
