Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Ohlins R&T top mount swap??
Old Sep 23, 2018, 08:52 AM
mi2slo's Avatar
Hey guys/gals
​​​​​​The clunking on my ohlins are getting to me, i was wondering if i can swap the stock top mounts over??? Been trying to search for an answer but couldn't find it.
Thanks
Old Sep 24, 2018, 01:10 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Are you sure everything is tight and that you don't have a blown damper? Ohlin's aren't very clunky in my experience.
Old Sep 24, 2018, 08:27 PM
mi2slo's Avatar
Well they do come with pillow ball mounts, so its bound to have the clicking/clunking noise. Im gonna pull it off this weekend and check it, but just wanted to know if i can swap out the stock top mount to the ohlins.
Old Oct 2, 2018, 08:05 AM
Dallas J's Avatar
The bearings in the Ohlins definitely wears out over time and will lead to that clunking. They're about $80ea to replace cause its a funky size, PSI usually have them IIRC. Ive looked for alternative sources but ~$15ea directly from china was as cheap as I could find but required 100 min order.
EGbeater (Nov 12, 2023)
Old Nov 7, 2022, 10:46 PM
FckingTrippy's Avatar
bringing this back from the dead
halp with link to bearing please!, ohlins very noisy, pillow ***** taking a dump
Old Nov 8, 2022, 10:58 AM
splattj's Avatar
The part number is 05536-51
Looks like they run $115 so you might consider popping it out, getting the ID,OD, and thickness and ordering un unbranded bearing.
Old Nov 9, 2022, 10:45 AM
CDrinkH2O's Avatar
@FckingTrippy If you have the R&T MI-100s, the standardized bearing type number is MBWT-16. I got mine through RHDJapan (SKU 63423) at ~$42 each.
Evo_Goodness
Aug 25, 2017 01:26 PM
merchomini
22
Aug 28, 2013 07:28 PM
Rafael Delgado
18
Feb 22, 2012 07:10 AM
derbrylac
Jan 19, 2011 04:33 PM
Turbo_Saloon
Sep 30, 2010 02:20 AM
Quick Reply: Ohlins R&T top mount swap??
