need help with tpms service required?
here is the story several days ago i had a flat tire and i needed to use the sapre one drove like that and on the dash came that the system requiered service also when i fixed the tire the guy that worked on it broked the sensor so i had to order a new one,know that i have placed the new sensor in the tire the warning from the dashboard doesnt go away it still says service required i tried disconnecting the battery but had no luck its still there so what do i do?
thanks if i use the old sensor will the service required go away? i want a tool to do this on my own the mut3 in my dealer doesnt have the latest info for my car i went to them and they cant reset the system what do i do? thanks guys |
well i had to install the old sensor back and now its all fine the thing is that when the sensors fail and you have to buy new ones someone must make a diy tool to reset the new sensors.
we are waiting on compatibility for the tool for mitsubishi. check the other thread
