Need help with RP03's
About to pull the trigger on Enkei RP03's in 19x10+22 with 275/35/19 Pilot super Sports. Need some advice on if this will work without rubbing or causing any issues. What do you guys think?
What is your suspension set-up? Camber specs?
1 Attachment(s)
Originally Posted by eve-slow
(Post 10074713)
I'm hoping the end result will be like this. This is not my first wheel choice, but I can get these with the tires for less than I would pay for Volks or Advans alone. And at 24lbs, the weight is pretty good for a $400 wheel. |
Ninja
Just realized I was in the X forum, sorry. :D |
Originally Posted by EVO LVED
(Post 10075295)
Originally Posted by Iowa999
(Post 10076451)
If you care about weight, then you probably care about performance. So why are you putting 19" wheels on your car? Are you swapping in a giant brake kit?
It depends on your drop and camber settings. The front will likely rub on full lock and the rear would need a roll.
Originally Posted by jdm sam
(Post 10078028)
(Post 10077121)
Not at this point, but the car could certainly use it, the STI brakes way better than the EVO. This is a street setup, so I'm willing to trade a little bit of performance for a little bit more of a sicker look.
We're actually 1% better balanced than an STi, but we weigh about 250# more. Maybe our CG is higher. That could be the balance thing that you can't pinpoint. Wouldn't surprise me. Boxer is nice and low.
edit: Nope. Bad guess on my part (that I should have looked up before suggesting). Lancer Evo: 509mm WRX STi: 534mm |
I think it also has something to do with the ABS. I find it just works better on the Subie. Panic braking on the street seems a lot shorter. Could also be tires. The RE070's on the STI are pretty damn sticky.
But please guys, back to the setup. =) |
(Post 10078241)
Well again, I'm stock right now. So will it clear stock? I guess what I really want to know is if this will clear with some reasonable negative camber, say -2 or less, and maybe a slight roll. Or will it take more than that?
(Post 10080453)
It will clear on stock just don't weigh the car down, wheel gap actually helps on that size tire/wheel. You really need to run 275/30/19 as the 35 will be too fat of a profile on the 19s.
So a little negative camber abd a mild roll? |
| All times are GMT -7. The time now is 01:02 PM. |
