Rear fenders rub after installing 18x9.5 +20 with 245's
3 Attachment(s)
Last weekend, I installed a set of Work CR Kiwami, size 18x9.5 +20. Since I was using 245/40/18's on them, after reading all the threads re: wheel fitment, I figured there would be no rear fender interference. Well, that was not the case. I was getting a slight rub, especially on the right rear making left turns over bumpy roads. The car is lowered on Eibach springs, and BFG G-Force Comp-2's are the tires I'm using. Comparing specs to the OEM Yokohama's, the BFG's are more square and have a slightly larger diameter, and that's more than likely the reason why I was rubbing while other people stated their cars were fine on 245's. I said "was rubbing" because I ended up getting the rear fenders shaved today during lunch. This way, I can go 265's with the next set of tires.
Just thought I'd post this info, in case anyone is interested. |
looks Excellent!
Here's what I would do, ACM: flip the front camber bolts to -2, set the rear to -1.5 and the rubbing will be gone and the car will handle better.
Shaved? Please tell me the inner lip wasn't cut back or off? You'll regret that if so.
Originally Posted by Adio
(Post 10424383)
looks Excellent!
Originally Posted by Iowa999
(Post 10424391)
Originally Posted by SD_Lurker
(Post 10426681)
Originally Posted by acm_evo
(Post 10433365)
Thanks for the input. However, I'm running around - 1.5 all the way around, and inside thread tire wear is bad enough as-is...
(Post 10433451)
What's the toe?
Well, then the issue with the rubbing in the rear really boils down to the incredible tread-width of the Comp-2s. With the same rear alignment, my R-S3s are no where near the fender lips on a +23 offset, for example. But, of course, a 245/40/18 Comp-2 is almost an inch wider at the tread than the same-size R-S3. Let this be a general warning to everyone that you have to take the tire's specifics into account when using what people have said will fit without rubbing.
Have you tried to figure out where exactly it's rubbing? I've fitted some big wheels and tires on an X, and have them fitted perfectly without rubbing; only needed to roll the fenders flat. I would advise you to pull a shock off, compress the wheel, and see where it rubs. Then address that issue.
(Post 10434157)
Originally Posted by chu
(Post 10435069)
(Post 10434157)
this kinda sucks, cause i was planning to get these wheels with some 265's in the spring... |
(Post 10435461)
Oh yeah, they were rubbing (slightly) on the outside rear fender lip, right at the top of the fender arch. And I did address the issue; boy did I ever...:) |
I have the exact same wheels but I'm lowered on swift spec r. I currently still have the OEM tires so there is a slight stretch, but I certainly don't have any rubbing issues.
