Ohlin Road & Track dampening/rebound setting
Hi all,
I'm starting this thread to gather some information on how many clicks people are running with their Ohlins which may or may not influence my decision to change what I'm currently running. I first tried 10 clicks from softest setting as I found this is the recommended setting from the instruction manual. I thought this was the correct setting assuming you would start counting from 0 (softest setting). However I've had a good look over the forums and it seems many people believe it is 10 clicks from the hardest setting not the softest. I'm now a bit confused :confused: 10 clicks from softest setting rode very nicely in terms of comfort. On the street I found it handled exceptionally well. 10 clicks from hardest setting, after reading many people were running this setting and with my track day coming up this weekend I thought I would give this setting a go. I've only been around the block but this setting still feels quite comfortable though it is noticeability more stiff and gives the car a more raw feel. While testing this setting around the block I managed to kick the rear end out while exiting a round-about which i was quite surprised as I thought I wasn't going all that fast. If anyone has played around or has some personal experience/knowledge of a good setting please shed some light. I've got a track event coming up and I'm chasing a balanced set up between oversteer & understeer. mods are: Whiteline roll centre adjuster Whiteline front caster kit Whiteline rear swaybar & endlinks Cusco front lower control arm brace Beatrush Rear Strut brace :helpme: |
Whenever you adjust dampening on the Ohlins, you need to go full firm first and then dial back the number of clicks you desire each time you want to try a new setting. The Ohlins have 30 clicks in their range so in the instructions under recommended settings, the "10 clicks" is still on the firmer side and will likely be a good starting track setting assuming you're on the out-of-the-box rates (10k front/7k rear) and on street tires that are comparable to the factory tires. Full soft (again, starting from full firm) will be dialing back 30 clicks and is quite comfortable on the street. If you have firmer rear spring rates (many people do 10k springs all around and that's what I had previously), you may find it preferable to run the rear a little bit stiffer than the front to balance it out. My street setting was 30 clicks front/28 rear since I have a rear sway bar (If I was on the factory RSB and had a 10k rear spring, I likely would've run 26 clicks in the rear for street driving).
These kits and settings are designed around factory setups (like suspension geometry, tire/wheels sizes, sway bars). If you have stickier tires you may have to firm them up a little more but it seems you don't have to worry about it on most street summer tires. Since you have a larger rear sway bar and adjustable end links, you may find it preferable to use a little softer dampening in the rear depending on the sway bar settings (by 1-2 clicks). I would suggest starting your sway bar on full soft though and see how you like it. If you're rear is kicking out abruptly, I have found that to be an indicator of the sway bar being too stiff (but then again, maybe you like that). All the best! |
I'm on full soft and loving it :D I need to mess with the dampening soon myself. The only thing that's a bummer is you have to go under the car to adjust the fronts. Oh well, bigger problems in the world.
cheers for the advise guys, I have now soften up the rear by 2 clicks after what JDIZZLE37 said about there recommendations based on factory set up and because I indeed do have the larger rear sway bar which makes the rear less grippy. Ive only adjusted it and have not driven the car yet. As for the sway bar its in the middle setting. Ive only ever had it on the middle setting.
Tyres are 245/40/18 AD08R on Enkei PF-01 18x9 et35 |
I'm curious to hear what damper settings people are using for DD cars with Ohlins R&T. I've been at 23/17 with 7k springs for over a year. Its been pretty good for all around use. I have bumped up to 8k springs and wondering if there is any need to bump up the damper stiffness.
i am doing 20-17 click, and off shelf rates (10-7). to me its perfect for a bit more spirited dd. lol
pretty amazing we found the same rear numbers of click for the same rate :) i am running 275 tires all around, and the car has stock weight, SSL |
You are girls...LOL
My car is on 10k/12k (valved accordingly), I run them at 14/12 clicks on the street on the 265 RE11's. NT01's on track need them cranked down to about 6 clicks out depending on the track. |
(Post 11755649)
You are girls...LOL
My car is on 10k/12k (valved accordingly), I run them at 14/12 clicks on the street on the 265 RE11's. NT01's on track need them cranked down to about 6 clicks out depending on the track. :D:D:D:D:D:D:D |
(Post 11755649)
You are girls...LOL
The ohlins do a great job of masking high spring rates.
Originally Posted by mrfred
(Post 11755713)
Yeah, on the soft side by high performance standards. One thing that I don't understand is that I've driven another Evo with R&Ts with 11k/11k springs and Ohlin's default damper settings, and it seemingly rides nearly as comfortably as mine. And he has the same suspension bushings as I was running. I had my dampers at the default settings before, any sharp edged bumps beat the crap out me.
I have never played spring rates with Ohlins in my car. So i am wondering should i do then a harder springs. But my 99% of driving with this car is dd, not track. |
My friends X has 10k/10k on the stock valving from Ohlins. Says it rides as good as his Infiniti Q50 daily driver.
(Post 11755772)
Q50 was stock struts with Stillen lowering springs. I rode in the Q50 before and after the springs, they didn't really change the ride, at all.
I have Ohlins on my NC Miata revalved for 12k/7k springs. Standard Ohlins springs are 7k/4k. The ride at 20 clicks from full stiff is pretty compliant considering the weight of the car and the spring rates, easily daily-able. But you're not exactly gonna confuse it with a camry. maybe something hardcore performance oreinted like Porsche's GTx cars. its stiffer than I remember by Evo X being on GTWorx springs. turning the damping stiffer quickly puts it into rattle your fillings loose territory though.
