Enkei RS05RR rims tire size recommendation.
whats up guys. I currently have Enkei RS05RR 18x9.5 / 5x114.3 / +22 (Face M) rims on my Evo X (got this especific one because it clears the brembos). I have looked up forums and see that people use 265/35/18 for these rims so i went with that and it fits perfect. Issue I’m having is that i have tire letterings in my tires and due to them being meatier tires the tires seem to rub against the back of the fender lining and it has messed up my tire lettering, does anyone know another size tires that may work with these rim’s specs. Thank you. |
Just roll the rear fenders.
(Post 11833030)
Use a heat gun to warm the fender liner up, and push it back out of the way.
(Post 11833904)
I have 18 x 9.5 +22, but went with cheap Rotas.
The 4 variables in this....and people rarely state more than 2 are: 1. Suspension, stock or otherwise. 2. Alignment, stock or crazy Civic look. 3. Tire size. 4. Tire brand. Check out the MFG stats. Section width varies between companies and models. Milimeters matter here. I've had 275/35 since 2013. First on Dunlop Direzza II, and now on P-Zero Runflats. Only notice rear rub on heavy bumps with a big load in the trunk. Only hit front inner fenders at full lock for the first 3 months. Now the clearance is rubbed in by the tires. Zero other issues. Key is that I have stock suspension and alignment. Its a great set-up. |
Originally Posted by 1fastmf
(Post 11834330)
