Need brake help asap
Old Mar 9, 2006 | 07:49 PM
prettytricia88's Avatar
ok so my bad if there is already a thread about this but i dont really have time to go searching..
we just put on my new brake pads... Hawk HPS onto my 05 EVO VIII... just as reccomended by fellow evo mers..
But now there is a HORRIBLE banchee squeal noise that wont go away... it doesnt happen every time you hit the brakes, but its enough that it cant be ignored.. although it only seems to be on the drivers side...
we put on the greese, and we warmed them up and used them as intructed but to no avail...
It would be great to get this awful noise taken care of tonight... who can help me figure out what the hell is going on???
Thanks a million in advance!
Old Mar 9, 2006 | 07:54 PM
Evoryder's Avatar
ELIMINATING BRAKE NOISE
by Larry Carley, Copyright 2000 CarleySoftare.com
Getting rid of an annoying brake squeal is like trying to cure a bad case of herpes. You can treat the symptoms and improve the patient’s condition. But it’s virtually impossible to eliminate the underlying cause. Fortunately, brake noise isn’t caused by a virus. It’s caused by a combination of factors that sometimes add up to create noise.
Brake squeal is really a high frequency vibration. In disc brakes, it can be caused by vibrations between the pads and rotors, the pads and calipers, or the calipers and their mounts. In drum brakes, the vibrations can originate between the shoes and drums, or between the shoes and backing plates.
We can’t say why brake noise is so annoying. It just is. To some people, it has the same effect as scraping your fingernails across a blackboard. They can’t stand it, even if it is "normal" for many vehicles today. Most people want nice, quiet brakes that stop smoothly with a reassuring "shhhhh" sound. No scraping noises. No high pitched squeals that would make a dog howl. No concerned looks or stares from passengers, other motorists or nearby pedestrians who wonder if the vehicle is going to stop or not.
Brake noise can also be worrisome to many people because they fear something is wrong with their brakes and their vehicle might not be safe to drive. Noise may indicate trouble, but the only way to know for sure is to inspect the brakes. If you find nothing amiss (no worn linings, or loose, damaged or missing parts), then you can reassure your customer and recommend any or all of the following measures to deal with the noise problem:
Dampen the pads
Lubricate the calipers
Replace the caliper hardware (slides, pins or bushings)
Replace the pads
Resurface the rotors
Clean the brakes (drums)
SHAKY PADS
One way to quiet noisy pads is to make sure the pads fit tightly in the calipers. If the pads on a single piston caliper have mounting ears or tabs that need to be bent or hammered to hold the pad in position, make sure the pad can’t be wiggled by hand. If the pads have clips, shims or antirattle springs, make sure the necessary hardware is in place and properly installed. If you see no such items when you inspect the brakes, don’t assume that none are needed. The last guy who worked on the brakes may have left them off. It’s always a good idea to look up an illustration or parts list for the brake system to make sure all the required parts are there.
If the pads are installed correctly but are still noisy, one of the least expensive and most effective ways to quiet them is to remove the pads and install insulator shims on the backs of the pads. The shims, which are usually self-adhesive, act like little seat cushions to dampen vibrations between the pad and caliper.
Another option is to apply a noise suppressing compound to the backs of the pads. Some compounds harden to a rubber-like consistency to cushion the pads. Another good choice is to apply a moly-based dry brake lubricant to the backs of the pads. This type of lubricant is long lasting and won’t burn or wash off like brake grease can. If applying a lubricant to the backs of the pads, be careful not to get any on the front side of the pads or rotor!
QUIETING THE CALIPERS
The same approach can be used on the calipers. Cleaning and lubricating the caliper mounts can also help dampen vibrations to quiet the brakes. Vibrations here can be caused by worn or loose mounts or mounting hardware.
If the calipers are badly rusted or worn, they may have to be replaced. But in most instances, you can probably clean them up, lubricate the mounting points and return them to service. You may have to replace the caliper slides, pins, clips and/or bushings, though, if there’s too much play or looseness between the caliper and knuckle. Be sure to use a high temperature brake grease so the grease stays where it belongs.
NOISY PADS
Some pads are noisy than others. Semimetallic pads are typically the ones that cause the most noise problems because they’re harder than nonasbestos organic (NAO) pads. Their high metallic content often makes them squeal when metal rubs against metal.
The amount and type of fillers and binders in a friction material can make a big difference in the amount of noise a given set of pads or shoes produce. Ingredients such as graphite, carbon and "rubber modifieds" may be added to reduce noise. Brass is another ingredient that helps dampen noise (it also has a cleaning effect on drums and rotors). Some of the newest pads designed for quiet operation use a nonmetallic "ceramic-enhanced" formula to eliminate noise.
The design of the pads themselves can also affect the amount of noise produced. A chamfered leading edge on the pads eliminates the sharp edge so the pads will slide across the rotor without grabbing and vibrating. Slotting the pads also increases their flexibility so they can conform more easily to irregularities on the rotor surface to reduce vibration and noise.
Some pads also have a special coating that transfers to the rotor surface when the pads are first used. The coating material leaves a film on the rotor that reduces noise, vibration and also rotor wear. The transfer film also makes the pads less sensitive to variations in the surface finish on the rotors.
If the original pads are too noisy and can’t be quieted by insulator shims, noise compound or grease, therefore, replacing them may be the only way to get rid of the noise.
PAD REPLACEMENT
Some brands and grades of aftermarket brake linings are quieter than others. So you may have to experiment with several different ones to find the quietest set for a given application. But whatever you do, don’t substitute asbestos or nonasbestos organic (NAO) pads for semimetallic pads unless the friction material supplier says it’s okay to do so. Asbestos and NAO do tend to be quieter than semimetallics but can’t withstand the heat that semimetallics can. Consequently, if you swap asbestos or NAO for semimetallics in a front-wheel drive car or minivan where the brakes run hot, it can reduce the life of the linings significantly (up to half or more!) and increase the risk of overheating and brake fade.
After you’ve installed the new pads, it’s a good idea to break them in yourself before returning the vehicle to the customer (unless the pads are the "fully cured" type that do not require an initial break-in period). Not breaking in a new set of pads increases your risk of a comeback. A customer can glaze and ruin a new set of pads if he fails to heed your advice to go easy on the brakes for the first 200 miles. If he overheats the brakes by mashing down on the brake pedal at every stop light, he’ll cook the resin in the pads before it can cure and glaze the pads. He’ll then wonder why the new pads you installed to cure his noise problem don’t brake worth a darn.
Pads that require an initial break-in can usually be seated by making 20 easy stops from about 30 mph with at least 30 seconds between brake applications so the brakes have enough time to cool.
Whether a new set of pads need to be broken-in or not, you should still test drive the vehicle to make sure the brakes are operating properly and that your efforts to eliminate the noise problem have been successful.
ROTOR RESURFACING
In addition to replacing the pads, it may be necessary to resurface the rotors to cure a noise problem. To brake quietly, the rotors have to be in good condition, relatively smooth and flat. So if the rotors are rough, glazed or have not been finished properly, they’ll have to be resurfaced.
How smooth do the rotors have to be? OEM requirements vary, but generally speaking a surface finish that ranges anywhere from 15 to 80 microinches should be acceptable—though GM recommends a surface finish of 60 microinches or less.
Unfortunately, there’s no easy way to measure surface finish short of buying an electronic "surface profilometer," a device which drags a calibrated stylus across the surface to measure roughness. Profilometers are expensive and nobody except brake part and equipment suppliers can afford to buy them. So the next best way to check your work is with a "surface comparator gauge." This type of gauge, which is available from machine shop suppliers as well as some gasket manufacturers, generally costs less than $50 and has sample patches on a metal plate that you feel or scratch with your fingernail to compare finishes.
Another way to check the surface finish on a rotor is the ball point pen test. Write you name on the rotor. If the ink leaves a continuous line, the surface is smooth enough. But if the ink line is broken up into dots, the surface is too rough (or coated with grease!).
How you resurface a set of rotors doesn’t matter as long as you get a smooth finish. Bench lathes and on-car lathes are both capable of high quality finishes when used properly. But both require sharp tooling and the right feed rate and spindle speed or drive speed to produce a good finish. For best results, many experts recommend using round lathe bits. These will produce a smoother finish (up to twice as smooth as a new rotor!).
If the crossfeed rate is too high, the lathe bit can groove the rotor like a phonograph record. There will be too much space between the peaks and valleys on the surface of the rotor making it unacceptably rough and noisy. What you want are narrow peaks and valleys. This may require you to slow down the crossfeed rate or adjust the spindle or drive speed (if possible).
Specific operating recommendations will vary with the type of equipment you’re using, but if you’re turning rotors on a lathe with a fixed spindle speed (100 rpm) and a fixed crossfeed rate of .003 in. per revolution, you should get a suitable finish. On lathes with adjustable spindle speed and crossfeed, a speed of 100 rpm with a crossfeed of .002 to .008 in. should give satisfactory results. A silencer band or vibration dampening attachment should be used while turning the rotor to eliminate tool chatter.
After the rotors have been turned, the next step is to apply a crosshatch finish using a "Flex-Hone" tool (made by BRM Mfg.). The flexible beaded abrasive on the Flex-Hone tool works better than an abrasive pad in a drill or sandpaper, and will give you more consistent results.
A final step that’s often overlooked but is just as important as any of the others we’ve mentioned is to clean the rotors after they’ve been turned. Use warm soapy water and a stiff brush. This will remove surface debris from the rotors that can become embedded in the new pads you’ve installed causing them to squeal.
There are also aerosol "brake silencing treatments" that can be applied to rotors to help suppress noise. These are spray-on coatings that are applied to the rotors after they’ve been resurfaced. Some contain microfine aluminum particles, graphite and moly that fill in the valleys on the surface of the rotors and act as a temporary lubricant to help the new pads burnish in more gradually. This not only reduces noise but also helps the pads develop a better cure which actually increases the coefficient of friction slightly, according to one supplier of this type of product.
DRUMS
One of the leading causes of brake squeal in drum brakes is brake dust inside the drum. Removing the drum and cleaning the brakes, therefore, may be necessary to eliminate this kind of noise. Use an aerosol brake cleaner or brake washer to clean the brakes. Never, ever blow out the drums with compressed air because doing so blows zillions of microscopic fibers into the air—which you certainly want to avoid if the vehicle has asbestos linings.
Another cause of noise in drum brakes is poor contact between the shoes and drum. Heel and toe contact between the shoe and drum is often the culprit, and the cure is to either replace the shoes with new ones or to resurface the drum slightly to increase its inside diameter. New shoes are ground with a slight eccentric to compensate for drum wear. This moves the point of contact away from the ends of the shoes toward the middle. In the old says, mechanics used to arc shoes to match their shape to the drum. But with the concerns about asbestos, shoe grinding is pretty much a thing of the past (though it might make a comeback if and when asbestos is totally out of the picture).
Other causes of drum noise can include weak or loose hardware (replace it), and vibrations between the shoes and the raised pads on the backing plates (apply brake grease).
Old Mar 9, 2006 | 07:56 PM
elhalisf's Avatar
i had the same VERY loud noise when i put on the ferodo 2500. the noise went away after about 50 miles of driving.
but i would also check the brake dust shield. it could be rubbing against the rotor
Old Mar 9, 2006 | 08:00 PM
i just took one of the pads off.. and it almost looks like my rotor is cutting into it.. maybe i need to have them turned? could that have anything to do with it?
Old Mar 9, 2006 | 08:28 PM
dntdrvslow's Avatar
been dealing with my brakes, ferrodo pads all around, i had to replace rear pads and didnt get it dealt with quikly enough and scored my rotors, had them turned and they still have plenty of thickness. Havin front pads and my rotors turned for the second time in the front next week. Its normal stuff cant really get upset about it. All the ferodo pads gave me about 13,000 miles, spirited driving
xexitenglishx
11
Apr 4, 2008 09:33 AM
evoichigo
Oct 23, 2007 02:49 PM
eag36
Apr 17, 2007 05:29 AM
Girodisc Martin
Mar 7, 2007 09:50 PM
Stumpy221
12
Aug 29, 2003 07:47 AM
