Question about my awd drivetrain
Old Sep 18, 2006 | 02:04 PM
evo72man's Avatar
Question about my awd drive train..I need a picutre.
Looks like the boot cover on the drive train is ripped, the part located in the middle of the drive train not the one near the front transmission? Is that a problem or just there to keep out the dust?
Comments appreciated.
Old Sep 18, 2006 | 02:09 PM
hondafan's Avatar
what part of the drivetrain? pics would help a ton.
Old Sep 18, 2006 | 02:40 PM
evo72man's Avatar
drive train CV Boot
I dont have a picture but looks like its the CV boot cover in the middle of the drivetrain, does anyone have a picture? I can point it out. Does the cover do anything?
Old Sep 18, 2006 | 04:31 PM
andyktlee's Avatar
Pocket Mo
Keeps dirt and other road crap from working its way into that area. The boot covers grease and other stuff so you should get that replaced.
Old Sep 18, 2006 | 07:13 PM
hondafan's Avatar
yeah, if the boot is torn you definitely need a new one before the grease is contaminated with water, mud, and other road debris, which will in turn ruin the CV joint it covers to give you the famous CV "click".
Old Sep 18, 2006 | 09:19 PM
evo72man's Avatar
What do you mean CV click? It will start to make clicking noises while the car is motion?
Old Sep 18, 2006 | 11:17 PM
barneyb's Avatar
Any road grime that gets inside will cause this joint to fail. So, you can replace the boot now or replace the entire joint in a few weeks.
The same goes for axle boots. So, I recommend you check these any time you are under the car.
Old Sep 19, 2006 | 08:56 AM
hondafan's Avatar
oh, you mean the boot isn't on the axle? if it is, and the joint gets alot of grime and dirt, they usually start to click when turning while in motion. if it's not on the axle, i'm still not sure what boot you're referring to.
Old Sep 19, 2006 | 09:43 AM
evo72man's Avatar
I need a picture.
Can someone help me please. The dealer order the CV boot for the joint but doesn't look like it will be the right one because I explained its right underneath the center console and they are showing one CV boot for the drive train in the front of the car. Please post. Thanks
Old Sep 20, 2006 | 10:34 PM
barneyb's Avatar
I think he is referring to the lobro joint in the center of the driveshaft. They call it a LJ in the service manual. This joint can both flex and change in length. But flexing the driveshaft too much during removal will cut the LJ boot.
Part of the problem is you calling everything under the car drivetrain. There are front axles, rear axles and the driveshaft (called a propeller shaft in the service manual).
Old Sep 21, 2006 | 03:45 AM
andyktlee's Avatar
Pocket Mo
Take your car over to the dealership and let them take a look (or someone else that knows about evos) so that you will get the right part. Better safe than sorry.
