"High Flow Cat" question.
Stock Cats Vs. High Flow Catalytic Converter
Catalytic converters on most production cars are not designed for high performance engines. If you start hot rodding your engine and exhaust, don't forget to upgrade your cat too, since this will be a likely bottleneck. Be sure to check your local emission laws, as sometimes it is only legal to replace a catalytic converter if it is defective or broken. This is why many exhaust companies sell "cat-back" exhaust systems, which is basically the full exhaust from the exit of the cats, to the tailpipes. A good high flow catalytic converter will have an inlet and outlet the same size as the rest of the exhaust pipes to give you maximum airflow.
I have a high-flow CAT from Random Tech... it works great. The catalyst is located on wounded layers of metal that have less resistance than the stock ceramic type. It's as close to a straight pipe (CAT-delete) as possible while passing emissions, and your ECU wont through a CEL.
Just keep one thing in mind, high-flow units are louder than stock. So if you have an aftermarket exhaust already, it will only get louder with the high-flow CAT.
Also, some states conduct visual inspections of your CAT, and cops like to give "fix-it tickets", so make sure is comes with a heat shield so it looks similar to the stock one.
For an interesting read on Catalytic Converters... see http://en.wikipedia.org/wiki/Catalytic_converter
i have a helix HFC.
threw a CEL with it 5 months after i puting it on.
i was doing a long spirited drive that kept me in the top band of RPMs.
i heard it's the least restrictive HFS on the market. it's metallic (not cyramic). flows 30% better and will outlast any cyramic cat.
on my last car i blew a ceramic cat after 1 1/2 years.
