O2 sensor help!!!!!
Old Apr 28, 2007 | 11:50 AM
RAZOREXPRESS's Avatar
O2 sensor help!!!!!
I pinched the 4 wires of the rear o2 sensor and now the car wont start....dose anyone know if those wires be spliced?
Help needed asap!!!!!!!!!!!!!!!!!!!!!1
Old Apr 28, 2007 | 12:09 PM
need help,asap
Old Apr 28, 2007 | 01:40 PM
dose anyone know?
Old Apr 28, 2007 | 10:44 PM
EVO+IX+MR+SE's Avatar
o2 sensor does not cause a no start...Im a mechanic and also a smog tech...
Old Apr 29, 2007 | 06:03 AM
XK120's Avatar
Was your battery connected at the time?
Old Apr 29, 2007 | 06:10 AM
Jakeg97's Avatar
yes they can be spliced
Old Apr 29, 2007 | 06:28 AM
Happy Hazard's Avatar
Although they can be spliced, the wires are shielded and have a certain impedence lvl to them to give them ECU exact readings. Splicing them like you would a radio would cause havok to your ECU and afr. You are better off fixing it correctly by getting a new O2 sensor.
My .02 cents.
Old Apr 29, 2007 | 07:42 AM
well i spliced the wires,still dosent start....any ideas?
Old Apr 29, 2007 | 08:03 AM
Was the battery connected when you pinched the wires? Have you checked for any blown fuses or could you have possibly caused anything else while you were doing whatever it was you were doing?
And when you say the car won't start, what exactly happens?
Old Apr 29, 2007 | 08:24 AM
yes the battery was connected when i pinched the wires.The car turns over but its like its not getting fuel...what fuses could possibly be blown?which fuse box might they be in( under the hood,or inside?)
Old Apr 29, 2007 | 08:42 AM
Dlove316's Avatar
When you put the key and click it to on position, you should hear the fuel pump a bit. If you do not hear it then that is why your car doesnt want to turn over. Very high probability this is a fuse issue
Old Apr 29, 2007 | 08:43 AM
i fixed it thanks alot fot the help!!!!!!!!!!!!!!!!!!!!!!
Old Apr 29, 2007 | 06:19 PM
so wat was really wrong with it...
yitzac1990
Lancer Engine Management / Tuning Forums
12
Apr 9, 2019 10:19 PM
rydogg008
Jan 10, 2015 10:15 PM
InfernoVIII
Jul 15, 2010 02:50 AM
sharkm87
Jun 6, 2007 08:52 AM
Mitsu3
Feb 17, 2007 05:52 AM
