question about evo 9 fuel pump...
Old Aug 7, 2007 | 12:05 PM
kikiboi's Avatar
so does the evo 9 fuel pump flow more then the evo 8? also will the evo 9 fuel pump bolt in a evo 8 with no problems and modifications?
Old Aug 7, 2007 | 12:09 PM
whoang40's Avatar
It flows more. If you are going through the trouble, just get a Walboro pump for 80 bucks. Walboro flows more than the Evo 9 stock pump.
Old Aug 8, 2007 | 02:50 PM
B0ostedFr34k's Avatar
wat about the walbro on the 9 yield any benefits?
Old Aug 8, 2007 | 02:53 PM
80210's Avatar
It will yield benefits. But you can safely run 23 psi of boost on the stock IX fuel pump with a TBE.
Old Aug 8, 2007 | 03:38 PM
Danny23's Avatar
yes, the ix pump will fit the 8.
Old Aug 8, 2007 | 03:41 PM
johnguam's Avatar
you don't need a Walbro pump on the IX if you just plan on doing basic mods.
Old Aug 8, 2007 | 03:42 PM
TTP Engineering's Avatar
IX is a different part number and flows more than the VIII.
Please run a search on AMS fuel pump test.
Old Aug 8, 2007 | 07:20 PM
jfLip's Avatar
Here you go man. I had the same questions as you a while ago.
Evo 9 Fuel Pump vs. Walbro 255 Data
AMS Ultimate Fuel Pump Test
Here is some highlighted information from those threads:
so from my observations, if you have a 9 and are only looking to the most basic mods (TBE, intake, MBC), then the stock fuel pump IS sufficient to handle the fuel flow demands.
Information from the AMS thread:
We learned a few interesting things, especially with the EVO VIII & IX pumps. The EVO VIII pump has a pressure relief valve that opens up at around 65-68psi and the flow output drops dramatically after that, eventually going to zero flow around 75-80psi. The IX pump flows a little more than the VIII pump at lower pressures but doesn't dump the flow at higher pressures. That's the reason you can make decent power at higher boost levels with the IX pump.
Hope that helps
Old Aug 8, 2007 | 10:29 PM
80210's Avatar
Great info. Thanks.
Old Aug 10, 2007 | 09:33 AM
ya man thanks, great info there!
Old Aug 10, 2007 | 09:35 AM
silver evo8's Avatar
the IX flows more but y not just get a walbro, you can get the kit for like $100 bucks
Old Aug 10, 2007 | 09:41 AM
Tsurugi-san's Avatar
You can buy my old IX fuel pump --- I went with a Walbro . . .
Old Aug 10, 2007 | 03:50 PM
jfLip's Avatar
No problem, glad I could help
03evo8racer
Jul 29, 2017 07:34 AM
nikush
May 1, 2017 06:01 AM
evoholic3088
Jun 1, 2016 10:29 AM
solngv8
Jan 8, 2009 08:23 AM
k270kmh
Aug 11, 2007 03:23 AM
