Grinding Noise help please
Old Feb 6, 2008 | 09:26 AM
Atreyu_590's Avatar
This happened when i made to fast and sharp of a turn and got a little bit of wheel hop. it only happens at low speed then it goes away when i get up to like 25 mph. when its wet it seems to do it less. Also it does it when i go straight not just when i turn so i have no idea what it could be any input to this would be a great help. Thank you very much i forgot to mention it sounds metalic
Old Feb 6, 2008 | 09:30 AM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
possibly an axle??
Old Feb 6, 2008 | 12:10 PM
Atreyu_590's Avatar
idk i was thinking breaks...but im not sure..it sounds like it is coming from the right rear
Old Feb 6, 2008 | 12:19 PM
SiCKlEyWiKeD's Avatar
check your pads and rotors. Something might have got caught there. You can also jack the car up and wiggle the wheels by hand. If there's play it might be a wheel hub.
Old Feb 6, 2008 | 01:08 PM
lemmonhead's Avatar
do this, put it in 1st gear and go in a circle really really slow with the sharpest turn you can get and listen and feel if it grinds. Do it both directions, if it does grind i would change out your Differential fluid.
my stock car had that grind, i changed the fluid and presto all gone.
Old Feb 6, 2008 | 02:03 PM
Atreyu_590's Avatar
but it only happened after i got a bit of wheel hope would u still say it could possibly be the fluids? my friend said something on the break might be getting stuck at low speed
Old Feb 6, 2008 | 02:22 PM
lemmonhead's Avatar
you have to start from somewhere, do a visual , then change fluids then go from there.
Old Feb 6, 2008 | 07:23 PM
KeithD's Avatar
I would have someone sit in the back with the window down and listen to make sure you know what side it is on. Then pull that wheel and look at the brakes and axles. Then go from there.
Old Feb 6, 2008 | 11:18 PM
Atreyu_590's Avatar
the weird thing is that it only happens on occasion not all the time
Old Feb 11, 2008 | 10:00 AM
Atreyu_590's Avatar
bump
Old Feb 11, 2008 | 10:06 AM
mitsuboost30's Avatar
Axle..
Old Feb 11, 2008 | 11:33 AM
Mr. Evo IX's Avatar
If you have the HKS HiPower then It's your exhaust rubbing on the driveshaft. Do you have an aftermarket cat back section? Check 360 degrees around your exhaust right where the carrier bearing is on your evo. Common problem. Get another exhaust, hammer in yours, get different exhaust hangers, any of these should fix it if it's the exhaust rubbing. Does it sound like rock in your brake rotor dust shield?
see this post and many more like it.
https://www.evolutionm.net/forums/sh...ht=HKS+rubbing
Old Feb 11, 2008 | 04:42 PM
Jeeperjunior's Avatar
+1 For having a friend ride with you and find out where it is coming from.
Old Feb 11, 2008 | 04:48 PM
Jameson_IXMR's Avatar
This is silly, is your front undertray off? because sometimes the side wheelwell pieces can hit the brake cooling thing (if you have those).
Dylroche
Jul 1, 2016 12:12 PM
Addison Hesser
12
Nov 9, 2014 08:31 AM
crankIT
10
Aug 29, 2012 03:44 AM
deadbeatrec
12
Dec 19, 2007 11:06 AM
kanyewest
Jun 29, 2007 07:37 AM
