Newb Door Problem
Old Dec 21, 2008 | 08:08 PM
SpinninAll4s's Avatar
Newb Door Problem
So My Whole Passenger side door and mirror have lost power somehow? Im not sure what could of caused this, I got a wideband installed and ever since I have had this issue. When I go to lock the doors/roll down the window the door wont do anything, as well as the power mirror. I have checked the fuses too, any help would be appricated! Thanks guys
Old Dec 21, 2008 | 08:19 PM
DWs95AWD's Avatar
Check them again. Its a fuse.
Or go back and make sure you did not unplug or break anything while installing the wideban
Old Dec 21, 2008 | 08:30 PM
JdMhEaD's Avatar
Did you install the wideband? Or did someone do it for you? If someone did it for you, then get them to look it over. If you did it yourself, then check where you ran your wires, where you tapped your wires into, if you did at all, and make sure you did not loosen any grounds under the dash anywhere. You may have a short, but hopefully its just a fuse and easy to track down.
Old Dec 21, 2008 | 08:42 PM
Cool thanks jdmhead, I did look over the fuses that delt with the door (Door locks, Power window etc.) dident find anything..Also I did have the wideband installed by a local performance shop. Im not sure what wires where tapped into or what but its just really aggervating.
Old Dec 21, 2008 | 08:43 PM
I will try and look over them agian I guess lol, But its like -20 over in the Chicagoland area w/windchill. BRRRRR Thanks guys!
Old Dec 21, 2008 | 08:46 PM
DWs95AWD's Avatar
Ya I am in the only state in the US thats not cold.
Old Dec 22, 2008 | 02:57 AM
dontstartmoddin's Avatar
That's why I dont let anybody work on my car. That way if something like this happens I know exactly where to look to fix it.
