Power wire for AEM wideband?
Old Feb 27, 2009 | 12:26 PM
Jay644's Avatar
I just installed it and connected it with the wiring behind the stereo, it works fine but I have a ground loop whine now. I wanted to know if anyone had any other suggestions on where to connect the power and ground wire away from the stereo.
I currently also have my gages connected back there with no problem or whines. So I know its the ground on the wideband.
Old Feb 27, 2009 | 12:38 PM
Mr. Evo IX's Avatar
I connected mine to the power of the 3 OEM gauge circuit in my MR. Since you have an MR that should be a good choice for you too.
Old Feb 27, 2009 | 01:32 PM
Jay644's Avatar
Yea I used the wire harness from the gauges but still have the annoying high pitched whine.
Old Feb 27, 2009 | 01:50 PM
19DB794's Avatar
I have the same thing. When my headunit is on it happens but when I shut it off it goes away. IDK what to do about it.
Old Feb 27, 2009 | 03:41 PM
Jay644's Avatar
There is a ground loop between all the wiring. First i tried was grounding the gauges and wideband in the same spot but nothing changed.
I guess I'll try and ground the stereo with the wideband and see if that works.
Old Feb 27, 2009 | 05:55 PM
C130flyer's Avatar
I connected mine to the Key on power in the ignition harness, its the black and white wire.
Topdown
Aug 24, 2018 11:55 AM
asdfasdf128
Apr 17, 2016 06:24 PM
grat81
May 27, 2014 05:35 PM
Xearo
Apr 18, 2009 02:29 PM
bcustom152
Jul 18, 2002 12:44 AM
