Engine removal
Old Oct 16, 2010 | 12:46 PM
tbryant0226's Avatar
Engine removal
I'm taking my engine out of my Evo 9 (dropping it) and do I need to take out my cross member because it seems to be in the way...
Old Oct 16, 2010 | 12:50 PM
_mcjonnyp's Avatar
if youre taking it out from the bottom then yes.
Old Oct 16, 2010 | 01:34 PM
Rp
Ok then how would u take it out from the top
Old Oct 18, 2010 | 09:28 AM
4RETECH's Avatar
Remove/ move Transfer case.
Remove/ move transmission.
Pull engine from top.
Old Oct 18, 2010 | 02:39 PM
skipperbrent's Avatar
i pulled my evo 9 engine out thru the top with the trans still attached, i took crossmember out and lowered engine to ground and manuver it back up thru the top no problem
Old Oct 19, 2010 | 04:26 PM
a
yea that was the other option that i was going to consider doing. I just gotta take the crossmember out and drop the front side of the driveshaft with it because my bolt is stripped! anyways thanks for the help man.
Old Oct 20, 2010 | 05:31 AM
5LEEPERISAH23I's Avatar
Nice! Idk that you could drop the motor n keep the trans still in tact! That's awsome
Old Oct 26, 2010 | 08:11 PM
Smile yea
on the drivetrain, theres a metal line that you have to unbolt(19mm). was kinda hard to see, but noticed it when i had the engine on a cherry picker and shook it. It's actually going better than i expected. How long does it take you all to take out your motors?
kjsperformace
Aug 1, 2017 07:01 PM
datiger69
Jul 10, 2017 08:22 AM
CottageLifer
Outlander Sport
110
Nov 28, 2016 07:06 AM
evobanjo
Nov 2, 2016 02:03 PM
Tarvi Trees
Nov 16, 2015 03:11 AM
