EGR system Removal.. PLEASE HELP
Hi I have put a evo 7 engine into my evo 6. I have done my best to set it all up to how it was on my old engine... The evo 7 engine has a stock turbo and it did have a EGR system witch I removed. I put my evo 6 inlet manifold on so there's no sensors at all.. when I removed the EGR system I was left with 2 holes in the exhaust manifold witch I plugged with some bolts???? Is that the right thing to do?? cause of how the manifold joins the 2 ports together on each end....???
My car runs like a ***** when I drive slow.. It stars ok an idles ok maybe with a slight miss. When I drive it slow it like starves for fuel with like a flat spot... When I give it some revs an boost it drives like it should.. all good under load..
I don't know what to do. I have changed just about every thing over from my old engine.. No vacuum leaks. The only thing l can think of is the manifold were the egr was in place.. Any ideas would much appreciated..
Do you have any pictures of these two holds, I can't seem to remember for the life of me where and what they look like. Also why didn't you just keep the factory evo 7 manifold and just just leave the sensor's in unplugged. I'm not wondering if the car is running poorly because so many sensors are not there?
fostytou
359
Oct 23, 2025 09:54 AM
