-   EvoM New Member / FAQs / EvoM Rules (https://www.evolutionm.net/forums/evom-new-member-faqs-evom-rules-61/)
-   -   jack/lift points on evo 9's? (https://www.evolutionm.net/forums/evom-new-member-faqs-evom-rules/446597-jack-lift-points-evo-9s.html)
KanzenR06EVO9MR Sep 14, 2009 07:19 PM
im looking to jack my car up and clean my brake calipers. i see the jack points for the rear. but where are the jack points for the front? any one have pics out ther of their evo on a lift. thanks
mr-derer2 Sep 14, 2009 07:24 PM
no pics but if u look under the car in the front ull see a tow hook on the frame. its dead center. u can jack from that spot. Or right behind the front tires on the frame there are some jack points too. u cant miss them. good luck!
raginghadron Sep 15, 2009 11:42 AM
Casting lvl7 search!
https://www.evolutionm.net/forums/ev...loor-jack.html
Cliff's notes: front crossmember good, front side rails good where material is doubled, rear side rails bad, rear diff good
chaotichoax Sep 15, 2009 01:36 PM
https://www.evolutionm.net/forums/at...oints_evom.jpg
LakerRaider Dec 19, 2009 03:14 AM
it says u can jack on the rer diff but what if i want to change my diff fluid?
evoll Dec 19, 2009 09:04 AM
Some good info,thanks for the pic.
EvoCop Jan 25, 2010 12:01 PM
word
Skylineracer Jan 25, 2010 12:10 PM
simple jack it from the diff and put to jack stands under the rails along the side of the car
howell Jan 25, 2010 12:14 PM
What about on the a-arms, that is typically where I Jack my cars up ( I haven't been under a evo yet, should own one with in the next month)
Skylineracer Jan 25, 2010 12:15 PM
that diagram is from mitsu follow it :lol:
brokenRS Jan 30, 2010 06:39 PM
Damn, my pinch weld is all sort of f'd up
howell Jan 31, 2010 08:06 AM
Alot of times the pinch weld is only good to Jack the car up with the factory Jack
delongedoug Mar 25, 2010 06:45 PM
:eek: Those are aluminum and a huge no-no.
SyZyGy1394 Mar 25, 2010 06:52 PM
You can get under the car to do the rear diff fluid without jacking it up. That is unless you are really fat. :lol:
I'm tempted to mill my jackstand tops so they match the pinchweld perfectly.
ALSO, do yourself a favor and go buy a real hockey puck for your jack. Measure the pinch weld and cut it into the hockey puck with a table saw. If you do it right, you will distribute the force nicely with the hockey puck.
