-   EvoM New Member / FAQs / EvoM Rules (https://www.evolutionm.net/forums/evom-new-member-faqs-evom-rules-61/)
-   -   Which 02 housing won't cause creep? (https://www.evolutionm.net/forums/evom-new-member-faqs-evom-rules/531627-02-housing-wont-cause-creep.html)
mitsuclipsegsx Dec 28, 2010 05:01 PM
Don't care which one has the most power, just looking for one that is less prone to boost creep. I was looking at map 02, jmf,indivia, BR, or just stock one ported. Anyone have luck with any of these? I know I could go with a dump but I don't want one.
Thanks:mitsu:
Kracka Dec 28, 2010 05:03 PM
Megan is what I used on my IX (well, actually it was the Buschur coated, but same as the Megan). I did used a Dremel + grinding stone to smooth out the interior though.
mitsuclipsegsx Dec 28, 2010 05:17 PM
And you didn't have any creep?
Kracka Dec 28, 2010 05:21 PM
None at all, completely controllable with both a MBC and GM BCS. I've installed quite a few Buschur/Megan o2 housings and haven't had any issues with them. I always like to grind off any internal ridges though.
BLK_EvIL Dec 28, 2010 08:17 PM
megan thats been ported
one4 Dec 28, 2010 10:14 PM
anything but ebay.
megan ported is fine... invidia would prob be the best option
icrnk Dec 29, 2010 06:30 AM
I think toxic fab was going to produce one. you should contact him. if i ever deviate from stock I will probably try him first.
Here is a pic of one of his: https://www.evolutionm.net/forums/ev...on-pics-8.html
Hopefully it will meet the following criteria as mentioned by another member
https://www.evolutionm.net/forums/se...ml#post7906463
Originally Posted by funks
I'm not gone - lol. I simply won't buy an O2 housing that doesn't have the support tab, IMHO - Mitsu put it there for a reason. Without it, the manifold is bearing all the weight (turbo + exhaust), my assumption is that it helps when the engine is moving around (during acceleration and such).
It's too bad the INVIDIA has it's o2 sensor located in the wrong spot (it does have the support tab though), and the WORKS costs so much you'd have to sell a kidney for one (it only works with their downpipe), nevertheless - it's out of topic now. Thanks for trying to see if it's feasible cost wise though. If you guys ever decide to make a non-dump O2 housing, coated, and the support tab in place, definitely interested (a plus too if it has support for the stock heat shield).
Paintballguy Dec 29, 2010 07:08 AM
megan is proven to be one of the best o2 housings performance wise. i have one on my evo.
mitsuclipsegsx Dec 29, 2010 07:14 AM
Thanks for the info guys. Anyone have jmf 02 housing, looks like a really nice peice.
RockmanX Dec 29, 2010 10:32 AM
I have zero boost creep with my ebay ss ported o2 housing and its getting the job done as im making power boss. I also had it coated by the beset in the business TiradoCustomCoatings. pmed
http://i444.photobucket.com/albums/q...x/DSC_1308.jpg
http://i444.photobucket.com/albums/q...x/DSC_1309.jpg
coated
http://i444.photobucket.com/albums/q...do2housing.jpg
mitsuclipsegsx Dec 29, 2010 03:10 PM
^^^ Did you port the inside of this one above?
RockmanX Dec 29, 2010 03:13 PM
nope they sell them in ported or non ported versions. You can send it off to any good shop and port it out if you want just dont take to much out or leave it alone and just coat it
erald01 Dec 29, 2010 03:25 PM
you can not port a megan o2 housing, but you can clean the weld spots a little. Megan is so far the most proven o2 housing ( comparing it from the best bang for the back point of view). None of the aftermarket o2 housing creep, it just depends what you are wiling to pay for. I dont think the oem creeps either....thats where twin scroll set up comes in handy
AKAweasle Dec 29, 2010 03:46 PM
i've been looking at getting a dump some day, will a dump get creep?
maperformance Dec 30, 2010 09:29 AM
No porting needed;
http://www.maperformance.com/map-tur...p-o2h-evo.html
