Intro from down under
Hi, I've been getting a lot of information from evolutionm for a couple years now, and though I'd get around to finally joining.
I have an ADM Yellow '05 IX, and had it since '07.
Not much done to the outside, but have spent a bit of coin on the engine and handling.
Once I'm happy with the power, I might start on a little cosmetic work.
Now it's time to enjoy it on the track.
Once the mod bug kicked in, my goals were to start with performance and handling, then cosmetics.
Engine:
Engine:
- 4" SD intake
- 792GTP turbo
- Turbosmart 26psi actuator
- Grimmspeed 3 port solenoid
- Synapse synchronic DV (bov)
- Flex fuel sensor
- Ported head
- Nitto 1.3mm head gasket
- Tomei baffle plate
- Tomei springs and retainer
- GSC zero tick lifters
- Supertech valves +1mm intake and exhaust
- HKS 2.3R stroker kit - forged pistons, crankshaft and H-section connecting rods
- HKS cam gear
- GSC R2 cams
- L19 head studs
- M&W Pro 12 CDI
- Black-Ops Injectors 1400
- Walbro E85 416 fuel pump, hard wired
- AI undercar surge tank with twin Bosch 044 fuel pumps
- Holley Dominator FPR with -8AN fuel lines
- Plazmaman fuel rail
- ORC 559 clutch (rebuilt)
- IX RS 5 speed gearbox, with TRE billet oil cooler, gear lubricator
- Built transfer case; stronger gear & pinion, Wavetrac diff
- Oil catch can by R.E.engineered Evolution Performance with -10 lines
- SME V5 manifold
- Custom 3.5" turbo back exhaust
- ETS 3.5" wide intercooler
- ETS short route titanium intercooler pipe
- Plazmaman hotside pipe with competition turbo outlet
- Ported stock intake manifold with EGR removed
- CP9A 42mm radiator
- MCA Red coilovers
- Rays TE37SL 18*9.5 (street)
- Rotor Grid-R 17*9.5 (track)
- Two piece carbon fibre driveshaft
- X3e strut brace
- Whiteline 26mm front sway bar
- Whiteline 24mm rear adjustable sway bar
- Whiteline roll centre adjust kit
- Whiteline bump steer correction kit
- Ralliart diff bushes
- DBA 4000 T3 rotors
- Elig street pads, Endless CC43 track pads
- Blox front motor mount
- Torque solutions shifter base bushing kit
- HEL braided brake lines
- HEL braided clutch line with restrictor removed
- Link plug-in ECU
- Racepak IQ3
- Battery relocated to boot
- Yellow stitch leather side pillars, armrest, handbrake cover, gearshift cover.
^ haha, thanks. It's suppose to be summer here at the moment, but it's been overcast all month. Lucky it was good on the day we headed out for a cruise.
I envy you guys, your cars have less restrictions resulting in more power.
I thought the US had tougher emissions' laws than Australia. You guys were able to get earlier versions of the GT-R as well as other high performance cars. Plus, you guys have those awesome Holden and Ford performance 4 doors. And, the Australian Supercars is probably the best racing on the planet. If you guessed by my comments that I love Australia, you are right. There are times I would love to bolt from where I live and move to Sydney. Anyway, keep us posted on your build.
I wasn't after a yellow one, but it was the only one available at the time. They are pretty rare, just need some carbon fibre to make it look better
A quick update, upgraded the turbo again, and pimped out the engine bay with a couple more things.
Car still needs to be tuned, have it booked in next month.
Got the car tune, but could only reach 26psi making 318kw's.
I was told the map size was too big, and couldn't get it past 26psi - turbo is capable of pushing 30psi.
An option I was told was to upgrade to aftermarket ecu...
Another Aussie here I saw this car at last weekends cruise I was in the black evo 9.
Your car was clean as man good job.
I'm interested in seeing how this turbo goes and also been following this build.
