feeling pretty stupid
Old Jan 11, 2012, 01:15 PM
stihlalive's Avatar
i feel like a dumbass asking but when doing an oil change on an evo how do u get all the oil out of the turbo and lines to insure a good oil change and the proper oil level.... sorry for the noob question but this is my first turbo car. i have done plenty of oil changes b4....
Old Jan 11, 2012, 01:28 PM
RSMike's Avatar
Generally you dont.
If you are really worried about it, you can change the oil, run the car up, then change the oil again.
It's not really required.
Get the engine hot, turn it off.
Drop the sump plug, allow the engine to drain. (Longer you leave it, the more it will drain).
When you put the new oil filter on, fill it with oil first. This will help you get oil pressure faster.
Reinstall the sump plug with new washer.
Fill the engine to "full" mark on dipstick.
Run the engine for 30seconds or so at 3000rpm, then turn off and recheck oil level.
Add oil as required
Old Jan 11, 2012, 06:51 PM
ROUND3's Avatar
If you wanna take it little further you can juck up the front endso the oil pan has a little more angle toward the drain...
Old Jan 14, 2012, 04:18 PM
stihlalive's Avatar
ha thanks guys, i know the procedure etc that when i do the oil change i always have too much oil in it because of what is left in the oil lines and turbo? idk ill have to start with alittle less oil let it settle then check it i guess
Old Jan 14, 2012, 11:29 PM
akeric's Avatar
Generally the amount is so small that it is not worth trying to get out. Most of the oil flows back to the pan after the car is shutoff. I wouldn't worry about it. Cheers
Old Jan 15, 2012, 01:23 AM
RSMike's Avatar
for our racecars we warm up the car, and run them @ 4000rpm.
Then quickly turn the car off and check the oil level.
This accounts for oil in the engine galleries and the head.
AWDTerror
Apr 25, 2013 10:57 AM
MrJuls
Apr 24, 2012 01:40 AM
S2K2EVO
Dec 29, 2010 08:19 AM
Skym
Jun 22, 2010 12:23 PM
andrewzaragoza
North Texas Evo Club (NTEC)
Jul 1, 2009 08:46 PM
Quick Reply: feeling pretty stupid
