NOOB here and I can't wait for an answer!
Ok guys, here's the low down.. I have had my Mitsubishi Lancer OZ rally for about a year now and man do I love it. When I bought it I knew that it had some problems which I would fix down the road, but recently there has been a problem that i couldnt fix and I was wondering if you guys could help. When accelerating, I hear this faint whistle noise, almost like hearing a dog whistle. I hear it when i open the throttle body or press on the accelerator regardless if its in gear or in netural. My car is a manual btw. I also just recently got this P0507 error when i took the car to autozone they told me that it could be a couple of things.
The noise isnt really effecting the car from what i can tell but i can hear it every time i shift up and accelerate , or rev the engine in neutral. The noise primarily comes when i just start to rev the engine if i keep my foot on the pedal at a constant rpm the noise will go away but if i press the pedal closer to the ground the noise will return then fade with the acclamation of the engine. Please if anyone has any sugestions id be happy to reply with any more questions!
sincerely -killdust
- A vacuum leak
- Leaking air intake after the throttle body
- EGR valve leaking vacuum
- A faulty positive crankcase ventilation (PCV) valve
- Damaged/failed/dirty throttle body
- Failed EVAP system
- Failed IAC (idle air controller) or faulty IAC circuit
sincerely -killdust
fostytou
338
Nov 10, 2023 11:55 AM
blackandredgts
Jan 1, 2014 07:26 AM
