evo8, evo8 gsr, evo8 rs-5, evo8 rs-6
whats the difference between all these??? since 99% of us probably have the evo 8... the RS r the ones that they r coming out this year right? the ones that have nothing in them saves like 80ibs a few thousand dollars cheaper, but everythign else is the same and most of all no ac?
EVO 8 GSR?
EVO 8 RS-5
EVO 8 RS-6?
EVO 8 GSR?
EVO 8 RS-5
EVO 8 RS-6?
The RS has no creature comforts, you can add most of them in the "urban jungle package". The RS also has a helical limited slip front dif., no ABS, and no H.I.D. lights. I believe the GSR is the standard Evo. The RS-6 a six speed maybe but, I haven't heard anything about that.
Re: evo8, evo8 gsr, evo8 rs-5, evo8 rs-6
Re: Re: evo8, evo8 gsr, evo8 rs-5, evo8 rs-6
Originally posted by RSXster
ive heard that the RS is more expensive then the normal Evo.
EVO VIII GSR is the standar EVO mostly focused for all of us. It has all the toys inside of it like A/C, PW, Standar gear box (6-speed), Active Yaw Control and it´s obviously heavier than the other two.
EVO VIII RS-5 & RS-6 are quiet different from the standar EVO GSR as you can see it just comparing the kerb weights: 1320(RS-5) vs 1410 or 1350(RS-6) vs 1410.
There are changes related also to front/rear track, lower fuel tank capacity but major differences are focused in the front differential (LSD for the RS´s), gear box (different gear ratios) and rear differential with the lack of AYC (for the RS´s).
EVO VIII RS-5....5 speed
EVO VIII RS-6....6 speed
EVO RS´s are shod with 15" rims instead of the 17" rims for the GSR.
The Japanesse EVO VIII features all what i wrote above (almost the same for those sent to the European market).
I dont know if 2004 USDM EVO will have the same specs but i hope that becoming true...you´ll really enjoy it!.
4g63girl
Sep 23, 2014 10:13 PM
