Ets vs buschur
Ets vs buschur
Tbe vs tbe are they about the same? I can get a ets with discount for about 200 cheaper then the buschur setup, and was wonder which should I go for is ets has long lasting Quality parts? And same power gains? Thanks
Both Buschur and ETS make the highest quality parts for our platform, it really comes down to personal preference. Little heads up though ETS doesn't make a turbo back exhaust as they do not make downpipes or 02 housings for our cars. They make everything from the downpipe back. However Buschur does make a 02 housing as well as a downpipe, I don't believe they make test pipes. So in order to get a complete TBE you might need to mix and match from different companies. HP/TQ gains will be pretty similar across the board, the only thing that varies is the weight of the system and the sound it will produce.
Turbo >> Muse 02 housing dump >> Perrin downpipe >> Perrin test pipe >> Tanabe Medallion Tousing Exhaust.
All my parts fit perfectly with one another, no issues at all.
As long as the parts are "stock replacement" then using various companies parts is fine. Take my exhaust for instance, this is it from the turbo back.
I loved my BR cat-backexhaust, I believe it's one of the lightest on the market and sounds good. If you want to make it quieter they sell a magnaflow muffler that takes the place of the hi-flow cat and helps.
An even more stealthly solution is the RRE cat-back exhaust, it looks even more stock than the stock exhaust and is very quiet (I'm old though) and you have to call them to order it as they don't list it on their website.
Should consider a titanium exhaust. Very cost effective weight savings.
http://www.maperformance.com/tomei-t...FRCBfgod53sAkw
Tomei also makes a Ti test pipe
http://www.maperformance.com/tomei-t...FY9cfgodGHIAag
