I think its time to move on...
So with the money I am saving for a closed deck engine and install on my STI, I am thinking about just instead paying off the STI (yeah not cheap to make a reliable 450whp in them) and trading in the STI along with some cash for an Evo 8 or 9 without major mods and under 50k miles in good shape to instead make my new project car.
What are some things I should look out for when looking at one to get and what could I also make reliably on an Evo 8 or 9 with a 15k-20k budget to build the car up?
Lastly, how can I change my username to a different one?
The closed deck 4G63 is much simpler in design & making power is less expensive. The crank has its own stock, casted girdle for support
Look at these thread stickies
https://www.evolutionm.net/forums/ev...oking-evo.html
https://www.evolutionm.net/forums/ev...g-dummies.html
Regarding your user name, let me know what you want it changed to
Thanks for joining us on the EvOM boards
Joe
Make sure timing belt, tensioner and water pump have been done recently. Also look out for Tcase whine. Evo transmissions are typically notchy, just make sure its not unbearable. Also ensure that all fluids have been changed, and preferably make sure the car has a nice/ decent tune.
Ive seen people make 400whp on a stock 9 turbo using E85 and supporting mods (depending on elevation). The 4g63 can handle 450 no problem, you would just need a bigger turbo and of course the supporting mods. 15k to throw at an evo is more than enough.
I dont know how you can change your username lol.
Edit: The man above has got your back on the name change
Yeah, we have the same opinion on the Suby. Great car, but the complexity of the boxer motor w/the open deck block is expensive & hard to work on
Joe
Joe
I think they did come out with an AP for the CT9A evos, however, it would probably be cheaper and similar to just use Evoscan, all you would need is a 1.3u Tactrix cable (around $100). Me personally, I wouldn't ever use an AP on an evo, and most tuners should be able to use Evoscan just fine. You would need to talk with your guy to see what he prefers I guess. You would also want a wideband, an omni 4 bar MAP sensor and maybe a boost gauge (I have a 4 bar for sale its BNIB ))
The ability to switch maps on the AP was always a plus, but not really all that appealing with how easy it was to work on Evos, plus their off-the-shelf maps weren’t anything great. Might as well pay a tuner a fraction of the cost for something custom and way better.
I have been able to find quite a few 6 speed evo MR with low miles compare to the regular evo with a 5 speed. would the rise in some cases of 50k more miles be worth it for the 5 speed or would the lower miles with a built up 6 speed or 5 speed swap later probably be a better choice?
I do, however, currently make more power on a 6 speed than I did on the 5, and it has not skipped a beat at 186k when the 5 started to have syncro problems at 75k.
Opinions differ, but that's what great about this community. Whatever information you seek, it's out here.
Depends on the power level. I much prefer how the 6 speed shifts, but they are not as stout as the 5 speed in most cases. I would take the one that you know was taken care of, not necessarily how many miles are on it.
Also yes, I am looking for ones that had low owners, low mods, and have as many records of service as possible.
k0lok0yboi
Dec 9, 2016 09:16 AM
evoreel
51
Aug 23, 2008 12:36 PM
93civEJ1
37
Dec 2, 2004 09:49 AM
