DriveLine Motoring///Defi Gauges Thread - BF's, Blue Racer's, and more!!
DRIVELINE MOTORING///DEFI GAUGES THREAD - BF'S, BLUE RACER GAUGES, AND MORE!!!
BF IMPERIAL LINK METER II:
Details:
- Control Unit II can control up to 6 Defi-Link Meter BFs at a time.
- Control Unit II can control up to 7 Defi-Link Meter at a time.
- Driving data can be stored up to 3 minutes and replayed.
- The switch panel is embossed and buzzers when the buttons are pushed.
- The charaters and the rings on the switch panel are illuminated in white at nighttime.
- Defi-Link Indicator (sold separately) blinks when any connected meter's warning LED lights up.
- Differential pressure between fuel pressure and turbo is shown if both of fuel pressure meter and turbo meter are installed.
- When the ignition is on, Opening Mode automatically begins.
MSRP: $149.00
PM FOR MEMBER PRICING
BF IMPERIAL DETAILS & PACKAGES:
BOOST GAUGE (PSI)
- 60mm
- Available in White, Amber, and Blue
- Requires Defi Link Meter
MSRP: $256.00
OIL PRESSURE 0-1000PSI
- 60mm
MSRP: $299.00
FUEL PRESSURE 0-600PSI
- 60mm
MSRP: $299.00
OIL TEMPERATURE 100-300F
- 60mm
MSRP: $224.00
WATER TEMPERATURE 70-230F
- 60mm
MSRP: $224.00
E.G.T. 400-2000C
- 60mm
MSRP: $299.00
INTAKE MANIFOLD PRESSURE
- 60mm
MSRP: $256.00
Defi Blue/White/Amber Racer Boost Gauge (psi)
Color: Blue, White, or Amber
Size: 52mm (2 1/16”)
MSRP: $192
Defi Blue/White/Amber Racer E.G.T Gauge
MSRP: $224
Defi Blue/White/Amber Racer Pressure Gauge
MSRP: $235
Defi Blue/White/Amber Racer Temperature Gauge
MSRP: $160
Details:
MSRP: $149.00
BOOST GAUGE (PSI)
- 60mm
MSRP: $256.00
- 60mm
MSRP: $299.00
- 60mm
MSRP: $299.00
- 60mm
MSRP: $224.00
- 60mm
MSRP: $224.00
E.G.T. 400-2000C
- 60mm
MSRP: $299.00
- 60mm
MSRP: $256.00
- Display range of -30inHG to +30PSI
- Stepping Motor drive: Quick response and high accuracy
- Performs Opening and Closing Ceremony
- Blue LED illumination with red arrow for easy all day visibility
- Adjustable outer bezel for manual setting
- Self-checking open / short circuit on the sensor and sensor connection
- Includes ABS plastic outer pod and metal mounting stand
- Does not require Defi control unit for use
MSRP: $192
- Display range of 400F – 2000F
- Sensor thread size of 1/8 PT
MSRP: $224
- Display range of 0PSI – 140PSI
- Sensor thread size of 1/8 PT and NPT adapter
- Pressure meter can be used for OIL or FUEL Pressure
MSRP: $235
- Display range of 0F – 300F
- Temperature meter can be used for OIL or WATER Temperature
MSRP: $160
