AEM UEGO Wideband Kits - $218.11!
Old Nov 14, 2008, 08:28 AM
ETS Michael's Avatar
Gauge-Type Wideband UEGO Controller. A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
Does not oscillate AFR reading like narrow band sensors
No laptop required for monitoring!
Bosch sensor included
Accurate to 0.1 AFR
Reads in AFR or Lambda via a switch in back of gauge housing
24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
Integrated three-digit display reveals AFR or Lambda in real time
User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
Serial data stream included for output of AFR (RS 232)
$218.11
This Special Will Not LAST LONG!!!
EmeryatSTM
11
Nov 28, 2008 08:42 AM
ETS Michael
ExtremeTurboSystems.com – WA
Nov 14, 2008 01:01 PM
extremepsi
Evo 'For Sale' Electronics / Lighting / Audio
Nov 14, 2008 09:58 AM
ETS Michael
Nov 14, 2008 08:40 AM
05-EVO-GSR
28
Jan 1, 2008 12:02 PM
Quick Reply: AEM UEGO Wideband Kits - $218.11!
