AWD Motorsports Evo X 2pc Aluminum Driveshaft!!! Solid Driveshaft Bushings!!!
We just received in our 1st batch of EVO X 2pc Aluminum Driveshafts.. These are ~15lbs lighter than stock and a huge loss in Rotational Mass.. Save some serious weight on the heavy Evo X.. This part will also absorb a lot of the shock put on the rear end and tighten up the driveline.. We also offer the solid Driveshaft bushings as well which we are giving away with the driveshaft right now..Check link below for pricing.. We will be offering deals to the 1st 10 people who pick these up.. So far 3 are sold.. PM for details.. Thanks!!
795.00 SHIPPED
http://www.awdmotorsports.com/index....mart&Itemid=29
Torque Solution Drive Shaft Center Support Bushings will replace the OEM Rubber mounts with billet aluminum pieces. Doing so will allow for reduced wheel hop, improved acceleration and better E.T's. The mounts keep the propeller shaft from moving under hard acceleration, stopping and turning giving you optimal performance 100% of the time out of your EVO.
These mounts fit all years Mitsubishi EVO VIII-IX & X.. A set of 4 is needed for the stock Driveshaft.. We are offering them for 50.00 Shipped per 4 and 25.00 shipped for 2 if you are buying the Aluminum Driveshaft..
