EVO X Camshafts Tomei, GSC, Cosworth, Brian Crower DEALS!
We won't be under sold on these items. So contact us today for a new set of cams!
NOW UNDER $500.00 FOR A SET, CONTACT US FOR THE BEST PRICE!
Available sizes;
Poncam 260IN/250EX - 10.10mm(IN) / 9.50mm(EX)
Procam 270IN/270EX - 11.30MM(IN) / 10.70mm(EX)
Procam 280IN/280EX - 11.30MM(IN) / 10.70mm(EX)
Above lift measurements are valve lift, max cam lift below;
Poncam - 10.30mm(IN) / 9.80mm(EX)
Procam - 11.50MM(IN) / 11.00mm(EX)
- Longer duration profile
-Intended for fully built engine
-Tuning and ECU mods recommended
-Stage 3 requires kit BC0130(BC Valve Spring + Retainer Kit)
Available sizes;
Stage 2 - 272/272 - 11.30mm(IN) / 10.64mm(EX)
Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM spring OK.
Stage 3 - 280/280 - 11.94mm(IN) / 10.64mm(EX)
Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires kit BC0130.
Available Sizes;
S1 - 264/264 - 10.20mm(IN) / 10.00mm(EX)
The GSC Power-Division S1 cams for the Mitsu Evolution X are designed for those with the stock turbo up to the 550hp range These cams will not sacrifice any bottom end loss over stock cams; nothing but gains and will promote faster spooling of the upgraded turbos. Gains of 20-50whp (depending on Turbo) have been seen by simply bolting the S1 cams in.
S2 - 274/274 - 11.20mm(IN) / 11.00mm(EX)
The GSC Power-Division S2 cams for the Mitsu Evolution X are designed for those with 600HP+ in mind. Gains of 40-80whp (depending on Turbo) have been seen by simply bolting the S2 cams in.
S2's require valve spring kit 5042!
Cosworth EVO X 4B11T Cams
MX1 - 266/266 - 10.80mm(IN) / 10.4mm(EX)
MX1 camshafts are a GREAT street camshaft, not to much lope at idle and can be used with the factory springs/retainers. This camshafts are highly recommend for any EVO X making 500whp and under with stock frame turbo!
If you just need questions answered, and want to inquire about more info, contact sales@maperformance.com or 1-888-maperformance.
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: NateAtMAP|||||: 1-888-MAPERFORMANCE|||||: Nate@MAPerformance.com
: The MAP blog - Get the inside track on what we're doing!|||||: Check us out on Facebook|||||: Follow us on Twitter
