-   EvoX 'For Sale' Engine Internals and Drivetrain (https://www.evolutionm.net/forums/evox-sale-engine-internals-drivetrain-285/)
-   -   RallySport Direct's Ultimate Engine/Drivetrain Thread! (https://www.evolutionm.net/forums/evox-sale-engine-internals-drivetrain/701600-rallysport-directs-ultimate-engine-drivetrain-thread.html)
RallySport Direct Oct 17, 2014 10:52 AM
1 Attachment(s)
RallySport Direct Oct 17, 2014 11:17 AM
18 Attachment(s)
CAMSHAFTS!
Brian Crower Stage 3 280 Camshafts Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
https://www.evolutionm.net/forums/at...ine=1413569836https://www.evolutionm.net/forums/at...ine=1413569836https://www.evolutionm.net/forums/at...ine=1413569836
Cosworth Camshafts MX1 Grind Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Brian Crower Stage 2 272 Camshafts Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
GSC Power-Division Camshafts S2 Grind Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
GSC Power-Division Camshafts S1 Grind Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
RallySport Direct Oct 17, 2014 11:24 AM
9 Attachment(s)
RallySport Direct Oct 17, 2014 11:32 AM
9 Attachment(s)
HEAD GASKETS!
Cosworth High Performance Head Gasket 1.3mm Thick Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
https://www.evolutionm.net/forums/at...ine=1413570740https://www.evolutionm.net/forums/at...ine=1413570740https://www.evolutionm.net/forums/at...ine=1413570740
Cosworth High Performance Head Gasket 1.1mm Thick Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING
Cosworth High Performance Head Gasket 1.3mm Thick 90mm Bore Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
RallySport Direct Oct 17, 2014 11:40 AM
10 Attachment(s)
ROD BEARINGS!
ACL Race Rod Bearings .001 Undersized Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
https://www.evolutionm.net/forums/at...ine=1413571225https://www.evolutionm.net/forums/at...ine=1413571225https://www.evolutionm.net/forums/at...ine=1413571225
ACL Race Rod Bearings Standard Size Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Cosworth Rod Bearing Set Size 0 Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Cosworth Rod Bearing Set Size 1 Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
RallySport Direct Oct 17, 2014 11:49 AM
10 Attachment(s)
CLICK HERE FOR MAIN BEARINGS!
ACL Race Main Bearings Standard Size Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
https://www.evolutionm.net/forums/at...ine=1413571796https://www.evolutionm.net/forums/at...ine=1413571796https://www.evolutionm.net/forums/at...ine=1413571796
Cosworth Main Bearing Set Size 0 Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
ACL Race Main Bearings .001 Undersized Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
Cosworth Main Bearing Set Size 1 Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
RallySport Direct Oct 17, 2014 01:27 PM
12 Attachment(s)
Valve Guides and Retainers!
Tomei Phosphorus Bronze Valve Guides Mitsubishi EVO X 2008-2014 / Hyundai Genesis Coupe 2.0T 2010-2013 CLICK HERE FOR PRICING!
https://www.evolutionm.net/forums/at...ine=1413577631https://www.evolutionm.net/forums/at...ine=1413577631https://www.evolutionm.net/forums/at...ine=1413577631
Tomei Titanium Valve Spring Retainers Mitsubishi EVO X 2008-2014 / Hyundai Genesis Coupe 2.0T 2010-2013 CLICK HERE FOR PRICING!
GSC Power-Division Intake Valve Guides Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
GSC Power-Division Exhaust Valve Guides Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
RallySport Direct Oct 17, 2014 01:36 PM
11 Attachment(s)
VALVE SPRINGS!
GSC Power-Division Single Beehive Valve Spring Set w/ Titanium Retainers Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
https://www.evolutionm.net/forums/at...ine=1413578191https://www.evolutionm.net/forums/at...ine=1413578191https://www.evolutionm.net/forums/at...ine=1413578191
Tomei High Performance Valve Spring Set Mitsubishi EVO X 2008-2014 / Hyundai Genesis Coupe 2.0T 2010-2013 CLICK HERE FOR PRICING!
Brian Crower Single Spring / Titanium Retainer Kit Mitsubishi 4B11T EVO X 2008-2011 CLICK HERE FOR PRICING!
Cosworth High RPM Valve Springs Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
https://www.evolutionm.net/forums/at...ine=1413578191[IMG][/IMG]https://www.evolutionm.net/forums/at...ine=1413578191
RallySport Direct Oct 17, 2014 01:58 PM
21 Attachment(s)
PISTONS AND SLEEVES!
Darton Iron MID Wet Sleeves Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
https://www.evolutionm.net/forums/at...ine=1413579503https://www.evolutionm.net/forums/at...ine=1413579503https://www.evolutionm.net/forums/at...ine=1413579503
CP Piston Set 86.5mm Bore 10:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 87mm Bore 10:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 86.5mm Bore 9:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 86mm Bore 10:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 87mm Bore 9:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
CP Piston Set 86mm Bore 9:1 CR Mitsubishi EVO X 2008-2014 CLICK HERE FOR PRICING!
RallySport Direct Oct 17, 2014 03:26 PM
9 Attachment(s)
RallySport Direct Oct 17, 2014 03:38 PM
1 Attachment(s)
RallySport Direct Oct 17, 2014 03:42 PM
6 Attachment(s)
RallySport Direct Oct 17, 2014 04:11 PM
3 Attachment(s)
RallySport Direct Oct 20, 2014 07:11 AM
Hope everyone had a great weekend!
Regards,
Jeff
RallySport Direct Oct 24, 2014 11:11 AM
Time for a bump!
Thanks,
Jeff
