2015 MAPerformance Evo X Master Engine and Drivetrain Thread
MAPerformance Master Engine and Drivetrain Thread Interested in any of the items listed below? PM or reply to the thread for pricing estimates. We respond to most inquiries within 24 hours! Shortblocks and Engine Builds http://www.maperformance.com/marketi...vox-stage1.jpg Stage 1 4B11T Shortblock Years of experience and hundreds of successful builds have given us a pretty good idea of what these motors like! If you're looking to make up to 600whp without having to worry about your bottom end you've come to the right place! http://www.maperformance.com/marketi...vox-stage2.jpg Stage 2 4B11T Shortblock Our stage 2 shortblock retains the factory crankshaft and connecting rod configuration and features Custom alloy sleeves for the ultimate in strength and durability! Various piston size options are available, supporting multiple displacements. Cylinder Head Preparation http://www.maperformance.com/marketi.../evox-ch-1.jpg Stage 1 4B11T Cylinder Head Preparation The MAP Stage 1 service is a great option for those looking to ensure that their cylinder head is in good working order and properly prepared for installation on a street or performance application. Please note there is no port work performed with this service. http://www.maperformance.com/marketi.../evox-ch-3.jpg Stage 3 4B11T Cylinder Head Port and Polishing Service The MAP Stage 3 service porting & polishing service starts with cleaning up the casting flash in both the intake and exhaust ports, improving bowl to seat blending, and unifying all of the ports to ensure even flow to each cylinder. Then we take it one step further with additional shaping of the bowls for even more airflow. Combine this with our world class machine work and you've got what we feel is the absolute best street/strip cylinder head on the market! http://www.maperformance.com/marketi.../evox-ch-5.jpg Stage 5 4B11T Cylinder Head Port and Polishing Service The MAP Stage 5 service improves upon our stage 3 cylinder head in several ways. We take the porting and polishing to another level through aggressive intake and exhaust work including our proprietary MAP “B” shaped exhaust port, improved bowl to seat blending including reshaping of the guide bosses, extensive reshaping and finishing of the combustion chambers, and unshrouding of the valves for improved flow. Proven to 1000+whp in 4g63 applications on both of our in house race cars we feel this is the best performing cylinder head on the market, period. Popular Items for Your Engine Build http://www.maperformance.com/marketi...ox/evox-vc.jpg Evo X Aluminum Valve Cover Mitsubish OEM Aluminum Valve Cover that is found on most EVO's from 2008 and 2009. http://www.maperformance.com/marketi...x/evox-hgk.jpg MAP H11 Head Stud and Gasket Package These studs paired with your choice of proven Cosworth headgaskets serve as a 1-2 knock out punch to keep the head on your high horse motor firmly seated where it needs to be! http://www.maperformance.com/marketi...x/evox-bct.jpg Evo X Billet Chain Tensioner by MAPerformance Made from the best Billet 6061-T6 aluminum, the Evolution X chain guide has been machined to meet the factory guide specifications with tighter tolerances to reduce chain wobble at high RPM's. It also implements the factory wear strip and is a direct bolt-on for the 2008-2014 Evolution 10. This timing chain tensioner is the last piece of the puzzle you need for a higher revving Evo 10. http://www.maperformance.com/marketi.../fd-pulley.png Evo X Harmonic Damper by Fluidampr Control power-robbing harmonic vibrations in your Mitsubishi Evolution X engine with a Fluidampr harmonic damper that uses race proven vibration damping technology. |
http://www.maperformance.com/marketi...nley-crank.jpg Manley Billet "Turbo Tuff" 94mm Stroker Crankshaft Fully Machined "Turbo Tuff Series", Billet For High Horsepower / High Boosted Applications. Features:
http://www.maperformance.com/marketi...o-pistons2.jpg Wiseco Forged 9:1 Pistons Valve pocket designs that allow maximum flow around valve, also allowing oversized valves ang high lift cams to be utilized. Piston crown shapes designed to promote maximum intake charge efficiency thru scavenging mixture "cross flow" during intake and exhaust valve overlap. More fuel and air equals more horsepower! Pistons designed to optimize squish or quench during compression combustion cycle event, resulting in resistance to detonation and pre-ignition. The end product is longer engine life and increased horsepower potential. Complex piston skirt profiles that reduce power robbing friction, yet promote stability in bore for optimum ring seal. Wiseco has added skirt coatings to the long list of standard features on stocked sport compact pistons! Precision machined ring grooves with proper orifice/accumulator volume using calculated groove root diameters and axial widths, featuring excellent surface finish and flatness providing maximum ring seal and minimizes blow-by and oil consumption. World class forging facility that utilizes the latest technologies featuring complex forged shapes, advanced materials, and featured aligned grain flow technology. http://www.maperformance.com/marketi...o-pistons1.jpg Wiseco Pistons 86.5mm 1400HD On and off the street, you can depend on the maximum strength and minimum variance of Wiseco's aluminum-forged pistons for your sport compact vehicle. Wiseco's pistons outgun cast and Hypereutectic pistons, giving you stronger pistons and tighter tolerances than any other part in your engine, with less internal and external machining. Our advanced forging process and extensive heat-treat and finishing process assure you of the performance and reliability you demand from your engine. http://www.maperformance.com/marketi...cp-pistons.jpg CP Pistons 86.0mm Bore / 9.0 CR CP pistons are compatible with oversized valves and high lift camshafts. Part numbers ending in a “X” are on a X-style forging for additional strength, durability and weight reduction. The X-style has a full radius dome design, high performance rings and light weight wrist pins. CP Pistons represent the highest quality and is engineered for maximum power. http://www.maperformance.com/marketi...ley-piston.jpg Manley Platinum Series Piston Kit Manley pistons are machined of high strength 2618 material. Each design is lightweight yet robust enough to deliver long service life. Offset wrist pin design is utilized for quiet start-ups. Perfect ring groove to skirt squareness is achieved through our unique "one fixturing" manufacturing method that assures maximum horsepower. All pistons come with moly coated skirts. Round wire locks, premium chrome moly wrist pins, and premium steel top ring sets from Total Seal are included with every kit at no additional charge. 9310 alloy upgraded wrist pins are available. http://www.maperformance.com/marketi...s/map-rods.jpg MAPerformance Ultimate Duty I-Beam Connecting Rods For those of you wanting the best rod available for your build, look no further than these as there is nothing better to be found! Our 4B11T Evo X Ultimate Duty Connecting Rods utilize strong 7/16" ARP 2000 Rod Bolts, not the weaker 2/8" bolts everyone else uses, and are built to withstand more power than you'd know what to do with! http://www.maperformance.com/marketi...nley-ibeam.jpg Manley I Beam Connecting Rods Manley Performance manufactures the finest steel connecting rods in the Sport Compact industry. Our Pro Series "I" Beam is forged from 4340 aircraft quality vacuum degassed material. We utilize our proven "Turbo Tuff" design and add 3/8" ARP 2000 cap screws. All rods are properly shot peened after machining and 100% magnafluxed. http://www.maperformance.com/marketi...nley-hbeam.jpg Manley H Beam Connecting Rods Manley "H" Beam connecting rods are manufactured from 4340 forgings to the same exacting standards developed and approved by our original equipment customers. There is a vast difference in quality between a Manley "H" Beam and the "other" inexpensive H-Beams on the market. Weight matched to +/- 1.5 grams. Perfectly round big and small ends. Bend and twist is tightly controlled. http://www.maperformance.com/marketi...ls/k1-rods.jpg 4B11T H Beam Connecting Rods by K1 Technologies The K1 Technologies Billet H-Beam Connecting Rods for the Mitsubishi 4B11 Engines are an excellent choice when looking to upgrade to a better set of Connecting Rods. These Rods come with 3/8" ARP 2000 Rod Bolts and we suggest them for applications up to 700 HP. http://www.maperformance.com/marketi...g-bearing1.jpg Race Main Bearings Set by KING Bearings Successful race engine builders are constantly pushing the limits of load capacity to new levels. Race bearings today inevitably need to match these demands with more competitive bearings. At King Racing we met the challenge with the XP high performance bearings series. http://www.maperformance.com/marketi...g-bearing2.jpg Standard Race Rod Bearings Set by KING Bearings The XP series is a line of bearings with advanced metallurgical and geometric technologies that meet extreme performance loads. It was developed for all performance applications that use forged steel aftermarket crankshafts and produce high loads for extended periods. King Racing’s XP series features pMax Black, a unique tri-metal structure that is 24% harder than any other conventional tri-metal race bearing. pMax Black together with the XP geometric features are the ideal combination for performance racing. Dont forget about the OEM Goodies needed with all engine rebuilds! We have the largest selection of Oil pumps, Timing chains, and full gasket kits than anyone else on the web, all at the lowest prices around! |
http://www.maperformance.com/marketi...ne/cc-stg2.jpg Competition Clutch Stage 2 Street Series 2100 Clutch Kit This assembly provides up to 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Brass Plus material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up. 300 ile break-in REQUIRED with this set-up. http://www.maperformance.com/marketi...ne/cc-stg3.jpg Competition Clutch Stage 3 Street/Strip Series 2600 Clutch Kit This segmented Ceramic material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for up to 150% increase in torque capacity. Provides quick but smooth engagement and extended life. http://www.maperformance.com/marketi...ne/cc-stg4.gif Competition Clutch Stage 4 Sprung Strip Series 1620 Clutch Kit This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides up to 250% increase in torque capacity. 300 mile break-in recommended with this set-up. http://www.maperformance.com/marketi...c-flywheel.gif Competition Clutch Ultra Lightweight Steel Flywheel The STU flywheel is recommended for forced induction and/or track and rally racing applications. This flywheel will work with ALL performance and stock clutch assemblies. http://www.maperformance.com/marketi...ne/cc-twin.jpg Competition Clutch MultiPlate Clutch Kit Competition Clutch provides the most economical racing clutch for the active sport compact enthusiast and is the preferred assembly for the professional racer. We currently offer our 4140 Forged Steel Flywheel with this unit to ensure durability in extreme racing conditions. http://www.maperformance.com/marketi...e/act-stg2.jpg ACT Heavy Duty Pressure Plate / Performance Disc Clutch Kit When your engine puts out performance, you need a clutch kit that can handle it properly. All ACT clutch kits provide a generous increase in clamp load which directly increases torque capacity. ACT Evo X Clutch kits are offered in a number of configurations and there is one developed specifically for your vehicle. http://www.maperformance.com/marketi.../act-6puck.jpg ACT 6 Puck Sprung Disc Clutch Kit After spending long hours and thousands of dollars building that high powered engine, you need a quality clutch that can properly transfer that power into motion. Count on ACT clutches for quality, performance and affordability. ACT recognizes that every driver and engine set-up is unique, so a variety of complete clutch kits and components are offered to match virtually any situation. ACT's complete clutch kits include a pressure plate, disc, release bearing, and (in most cases) a pilot bearing and alignment tool. The kit guide below will help you select the ACT kit that best fits your needs. http://www.maperformance.com/marketi...t-flywheel.jpg ACT XACT Prolite Flywheel ACT XACT flywheels in two versions, ProLite for road racing applications and very quick throttle response, and slightly heavier StreetLite for street and drag racing vehicles which may require more inertia. For example, the Integra ProLite weight 8.8lbs and the Integra StreetLite weights 12.5lbs. Both ProLite and Street Lite flywheels are precision made from Chrome-moly forgings and feature an induction hardened integral ring gear. All ProLite and StreetLite flywheels are CNC machined, heat treated for strength and precision balanced, Substantial material is left behind the clutch surface area for better heat dissipation and durability while weight savings is made where it matters the most for reduced inertia. http://www.maperformance.com/marketi...ne/qm-twin.jpg Quartermaster 8-Leg Street Clutch Kit Drawing on an extensive, race-winning heritage, Quarter Master® designed the all new 7.25" Mitsubishi Evo Race Clutch to perform well in a broad range of Evo X racing platforms. The new clutch utilizes eight integral steel hardened legs to provide a much longer lifespan than one-piece aluminum covers where the floater and pressure plates have a tendency to wear into the drive legs. The 8-leg design also reduces stress on drive legs by 25 percent and creates a stiffer cover and smoother range on the diaphragm spring motion. A lower moment of inertia and gear drive friction design allow for quicker, smoother shifts. In addition, the gear drive clutch hub is located on the friction pack to enable easier transmission installation, much smoother and quicker shifting, improved input shaft wear and increased hub strength. http://www.maperformance.com/marketi...ne/map-cmc.jpg MAPerformance Clutch Master Cylinder Upgrade If you've experienced a clutch master cylinder failure or are simply being proactive, MAP is here to help. We have seen the stock plastic clutch master cylinder fail with upgraded clutches and/or spirited driving; Here is a solution that anyone should be able to install with basic hand tools from the comfort of your own garage. http://www.maperformance.com/marketi...ne/tf-line.jpg Techna-Fit Clutch Line Kit All of our clutch lines are single lines made of stainless steel braided hose with a variety of hose ends. The length of the hose and ends will vary for each specific application. Bolts and washers are included if required. |
Looking for a sleeved 2.0 with turbo tuff I rods, no core. shipped 75052. Thanks
Originally Posted by Jubey97
(Post 11417641)
Contact us for some of the best pricing and service available!
What kind of parts are you in need for your summer build?
Let us know what you need to get your Evo street or track ready! 1-888-MAPerformance
Summer is quickly approaching! Purchase what you need to get you back on the road or track!
1-888-MAPerformance |
Give us a call today for all your performance needs! 1-888-MAPerformance
Let us help get you racing through the summer heat! Call in at 1-888-MAPerformance
Give us a call and let us help you pick out your next mod! 1-888-MAPerformance
We have what you need to complete your street machine or track monster! PM Me for the best possible pricing around!
Looking to attend a track day? Check out our check list to make sure you have the proper equipment! http://www.maperformance.com/track-d...aign=trackprep
These rules can be applied to any car! Intake, Exhaust, and a Tune are a MUST on a DD!
http://www.maperformance.com/3-Simpl...y-Driven-Evo-X |
