Affordable Fuel Solutions FIC / DW / Injector Dynamic / Walbro / Fuelab / MAP & MORE!
MAPerformance is here to EARN your business. We pride ourselves on offering the absolute best pricing and customer service available and our customers agree, we ARE your ultimate source for performance parts!
If you are interested a fuel upgrade but need direction please do not feel bad contacting us for a recommendation / pricing. Our expert sales staff has tons of experience in everything from road racing to daily driven applications and would love to help point you towards the right products, even if you're not ready to buy yet!
Fuel Injector Clinic (FIC)
Fuel Injector Clinic 650cc Injectors (127-0650H) $328.99
Fuel Injector Clinic 775cc Injectors (127-0775H) $359.99
Fuel Injector Clinic 900cc Injectors (127-0900H) $369.00
Fuel Injector Clinic 1100cc Injectors (127-1100H) $494.99
FIC 2150cc BlueMAX Fuel Injectors (227-2150H) $764.99
PM For Exclusive Forum Member Pricing!!!
DeatschWerks
DeatschWerks 850cc Injectors (21S-03-0850-4) $399.99
DeatschWerks 1000cc Injectors (21S-03-1000-4) $489.99
DeatschWerks 1300cc Injectors (21S-03-1300-4) $549.99
Deatschwerks 2200cc Bosch EV14 Injectors (16S-05-2200-4) $839
INJECTOR DYNAMICS
INJECTOR DYNAMICS 725CC INJECTORS (ID-725-EVOX) $472
INJECTOR DYNAMICS 850CC INJECTORS (ID-850-EVOX) $499.99
INJECTOR DYNAMICS 725CC INJECTORS (ID-1000-EVOX) $472.00
INJECTOR DYNAMICS 2000CC INJECTORS (ID-2000-EVOX) $960.00
MAPerformance Injectors
MAP 1000cc Fuel Injectors w/ PnP Adapters (MAP EVOX-FI-1000) $409.99
MAP 2000cc High Impedence Fuel Injectors (MAP EVOX-FI-2000) $649.99
Deatschwerks
Deatschwerks DW65 Series 265lph Drop-in Fuel Pump (DW9-651-1009) $149
Deatschwerks DW300 320lph Fuel Pump with MAP Installation Kit $269
Walbro
TI Automotive 400lph Fuel Pump with MAP Install Kit $279.99 (Non E85 Pump)
TI Automotive 400lph Fuel Pump with MAP Install Kit $340 (E85 Pump)
MAP AFPR Install Kit with AEM Fuel Pressure Regulator
Starting at only $294.99 this kit includes a AEM adjustable fuel pressure regulator, white face Turbosmart fuel pressure gauge, fuel rail adapter, mounting bracket and all necessary fittings to accurately adjust and monitor fuel pressure in your Evo X! Includes black and silver shadow series fittings for a cleaner sleeper look under the hood!
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: NateAtMAP|||||: 1-888-MAPERFORMANCE x 114|||||: Nate@MAPerformance.com|||||Click to chat for an instant quote!
K27 Surge Tank Kit $899.99
- 6061 aluminum construction
- AN fittings
- Walbro 255 fuel pump
- Weather proof relay and plug
- Bolt in tank installation
- Fits with stock trunk liners and sub woofer installed
- Requires no cutting of factory fuel lines to install
- E85 compatible hoses
- Lightweight re-enforced braided hose (standard hose available)
Benefits
- Eliminates fuel starvation in hard left cornering
- Increases fuel system flow capacity due to additional fuel pump.
- Eliminates potential fuel starvation due to failure of factory fuel pump relay
- Is compatible with the AMS in-line fuel pump kit if already installed
Due to the fuel tank design of the Mitsubishi Evolutions, the engine can experience fuel starvation when the fuel tank is less than full under hard left cornering. This surge tank kit addresses this issue by providing a reserve supply of fuel for an inline pump, preventing this fuel starvation, allowing you to run your fuel tank down to 1/8 of a tank or less. Custom fitting sizes available on request. It includes all hoses, fittings and wiring required for installation.
Finally, a fuel feed line solution for your EVO X!
This MAP fuel feed line kit replaces your entire factory feed line from the fuel pump housing to the fuel rail with 6an hose. Supplied push-on EFI fittings allow for an easy installation that requires no modification to your fuel pump housing or fuel rail!
Why replace your factory fuel feed line? Restrictions in the factory line cause pressure drop from the fuel pump to the rail; depending on the application a fuel pressure reading at the fuel rail might be 5, 10, or even 15psi lower than the fuel pressure at the pump. Take a gander at any fuel pump flow chart and you will find that fuel pumps flow significantly less at higher fuel pressures. To put this into perspective a Walbro 400lph fuel pump flows roughly 253lph at 90psi (13.5 volts) in comparison to 300lph when pressure is reduced to 75psi. An additional 50lph translates into almost 100whp of additional fuel capacity on E85!
This kit is available with or without a FueLab inline filter, however, please keep in mind that any aftermarket fuel pump (outside of the DW65C) will eliminate your factory in tank filter making this a pretty good idea.
Did you know that ALL MAP Fab in house manifolds are built with the following features?:
100 Percent polished schedule 10:
MAP invested hundreds of hours into developing a system to polish schedule 10 to our specification including research into the best possible tumbler, sampling a wide array of aggregate to generate the perfect finish to start with.
All manifolds welded on back purge stations
ALL MAP in house fabricated manifolds are tig welded and 100 percent back purged. This a process by which shielding gas is introduced to the interior of the welded area to prevent the molten metal from being exposed to oxygen. This results in stronger, more uniform and cleaner welds.
All MAP in house fabricated manifolds come with thick, laser cut/cnc'ed stainless flanges
Resulting in longer lasting and more aesthetically pleasing parts
All MAP in house fabricated manifolds come ported
Where some companies will simply grind away excess material for a simple transition into the runners, MAP manifolds are actually ported and shaped for maximum flow.
All MAP manifolds are backed by our Lifetime Ownership Guarantee!
When purchasing a MAP manifold, purchase with confidence. We guarantee that manifold for the lifetime of your ownership of it (valid for the original purchaser only).
MAP Complete T3 Turbo Kit (Mitsubishi Evo X)
The wait is finally over as you can now get the MAP treatment in a T3 configuration using some of the best components available! Choose from four killer PTE turbochargers (please don't hesitate to contact us for suggestions) and turn your horsepower dreams into a reality. This kit includes every component you will need to complete the installation.
Included Components
Turbocharger of your choice
3" Stainless Steel V-Band Downpipe with Flex
304SS Tubular Exhaust Manifold with CNC Transition Head Flange to 1.5" Primaries
Cam Angle Sensor Heat Shields (not pictured)
Turbosmart Comp Gate 40 Wastegate
Wastegate Dump Tube
Stainless Steel Upper Intercooler Pipe
Oil Feed and Return Lines
All Applicable Gaskets, Hardware, Clamps and Couplers
Included Components
Wastegate Dump Tube
MAPerformance stock frame turbos! Available for the EVO 8/9 (EVO 8 will require a conversion kit to fit an EVO 9 turbo available through us as well!) AND EVO X!
Power, reliability, affordability all in a stock frame turbo? It's as simple as that. MAP turbos use our MAP Billet wheel, dual oiling ports for improved lubrication and all EF3, EF4's include upgraded thrust bearings. Simply put, MAP is your answer for your stock frame turbo needs!
Customer satisfaction is our highest priority!
If for some reason you are not happy with your MAP turbocharger simply send it back to us within 30 days from the date of purchase and we will refund you 100% of your purchase price for that item.
Please note the turbocharger must not be damaged or altered in any way, and all accessories must be included within the return shipment.
AEM High Flow In-Tank Fuel Pump
The AEM High Flow Fuel Pump flows 320 lph (84 gph) at 43 PSI and is capable of supporting over 1,000 HP at 43 PSI.*
The AEM High Flow Fuel Pump is designed for in-tank mounting for use with gasoline and features a compact 39mm diameter that fits most applications. It has an offset inlet design that eases installations and includes a wiring harness, pre filter, internal fuel hose and clamps, end cap and rubber buffer sleeve. Every pump is tested to flow 320 lph at 43 PSI.
AEM High Flow Fuel Pump Features
Designed for high output naturally aspirated and forced induction EFI vehicles
In tank design
Tested to flow 320 lph @ 43 PSI
39mm diameter fits most applications
Offset inlet design eases installation
Each pump individually tested
For gasoline vehicles
Kit includes fuel pump, rubber sleeve and end caps, pre filter, hose, clamps and flying lead
In tank design
