Run up to two fuel pumps with Radium Engineering's hanger!
Old Oct 14, 2019 | 03:39 PM
Aristocrat Dave's Avatar
Radium Engineering's fuel pump hanger allows you to run 1 or two aftermarket pumps in the stock Evo X fuel tank. The machined assembly simply drops into the factory tank with the OEM hold-down flange. A low profile design keeps all wiring tucked underneath the OEM cover platem while nylon acorn nutts (included) prevent accidental short circuits. The in-tank wiring is insulated with a chemically resistant PTFE; the serviceable connections are properly sealed and designed to be impervious to all fuel types. Radium's fuel pump hanger includes a venturi jet pump with a new pressure-relief valve to minimize backpressure in the regulator. An included 2-piece anodized aluminum collector box which sits at the bottom of the fuel pump improves fuel supply around the pump inlet.
This kit includes the following items:
-Anodized Aluminum Mounting Plate
-Anodized Aluminum Collector Box and Check Valves
-Anodized Aluminum Venturi Jet Pump with Multiple Orifices
-Anodized Aluminum 8AN Male Pump Outlet Fitting
-Anodized Aluminum 6AN Male FPR Inlet Fitting
-Anodized Aluminum Fuel Level and Temp Sensor Bracket
-Anodized Aluminum Dual Pump Cradle
-Electrical Hardware for Fuel Pumps and OEM Sensors
-Fluorosilicone Duckbill Return Valve
-Submersible Rubber Fuel Hose
-Stainless Steel Hardware and Clamps
PM with your zip code for an accurate shipping quote! Will call pickup is available for Southern California customers from our Buena Park facility.
Facebook: https://www.facebook.com/AristocratAutosport/
Instagram: https://www.instagram.com/aristocrat_autosport/
Website: www.AristocratAutosport.com
CALL OR TEXT: 714-340-6596
Email: Sales@AristocratAutosport.com
Old May 16, 2024 | 08:07 AM
GabrielHenly's Avatar
Step into the lucky zone, enter to win!
Gadgets, travel, experiences - win what you want!
Aristocrat Dave
EvoX 'For Sale' External Engine / Power
Oct 10, 2019 12:03 PM
Aristocrat Dave
Sep 16, 2019 10:25 AM
Boostin Perform
54
Mar 17, 2014 06:14 AM
STALIZE
Mar 16, 2014 10:41 PM
Juiced
Jan 8, 2006 12:39 PM
