MAPerformance Fabrication & Porting Services
http://www.maperformance.com/img/forums/evom-header.jpg http://www.maperformance.com/img/forums/tb-maprace.pnghttp://www.maperformance.com/img/forums/tb-whymap.pnghttp://www.maperformance.com/img/forums/tb-services.pnghttp://www.maperformance.com/img/for...-clearance.pnghttp://www.maperformance.com/img/for...-customers.png http://www.maperformance.com/img/forums/sep.png The MAP Tubular Manifold for the Evolution X platform is now available! Click here for initial testing that resulted in an amazing 40whp+ gain with a BBX turbocharger! Polished http://www.maperformance.com/products/map_EvoX-TEM2.jpg http://www.maperformance.com/products/map_EvoX-TEM3.jpg Advanced Ceramic Coating (All Ceramic Coating orders can take up to 2 weeks before shipment) http://www.maperformance.com/product...M-coated1a.jpg - Direct replacement for stock frame Evo X turbochargers - 1.25" primaries for maximum velocity and spool characteristics - Schedule 10 304SS tubing for the utmost in durability - 304SS flanges featuring a CNC transition from cylinder head to primaries - Available in semi-polish (pictured) or with our advanced ceramic coating - Finish porting of CNC transition to primaries and merge collector - Fully backpurged TIG welded construction - Fits with OEM firewall heatshield - Lifetime warranty against defects to the original purchaser MAP Stainless Steel O2 Eliminator Downpipe for Evo X http://www.maperformance.com/products/evoxdump5.jpg http://www.maperformance.com/product...XDownpipe3.jpg This integrated O2 housing downpipe, or O2 eliminator as they are often referred to, does just that by removing some of the largest restrictions in the factory exhaust system for significant horsepower gains throughout the power band! Features / Benefits * Full 3" design reduces exhaust restrictions. * Made from 304 stainless steel for superior corrosion resistance and enhanced appearance. * Mandrel bent tubing throughout optimizes exhaust flow. * Stainless steel flex section reduces stress from engine movement increasing longevity. * Optimal wastegate dump location helps eliminate boost creep. * Includes stainless steel turbo outlet gasket (not shown). * 100% Made in the USA. MAP Stainless Steel CompGate40 O2 Eliminator Downpipe for Evo X http://www.maperformance.com/product...X-CG40-O2H.jpg Features / Benefits * Full 3" design reduces exhaust restrictions. * Made from 304 stainless steel for superior corrosion resistance and enhanced appearance. * Mandrel bent tubing throughout optimizes exhaust flow. * Stainless steel flex section reduces stress from engine movement increasing longevity. * Optimal wastegate dump location helps eliminate boost creep. * Includes stainless steel turbo outlet gasket (not shown). * 100% Made in the USA. http://www.maperformance.com/img/forums/sep2.png Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"! http://www.maperformance.com/img/forums/pm.png: Send us a PM|||||http://www.maperformance.com/img/forums/aim.png: NateAtMAP|||||http://www.maperformance.com/img/forums/phone.png: 1-888-MAPERFORMANCE x 114|||||http://www.maperformance.com/img/forums/email.png: Nate@MAPerformance.com|||||Click to chat for an instant quote! http://www.maperformance.com/img/forums/social-bl.png|||||http://www.maperformance.com/img/forums/social-fb.png|||||http://www.maperformance.com/img/forums/social-tw.png|||||http://www.maperformance.com/img/forums/social-yt.png Like us? Tell us and everybody else about it! https://seal-minnesota.bbb.org/seals...e-96087872.png |||||http://medals.bizrate.com/medals/dyn...2697_medal.gif|||||http://www.maperformance.com/img/google-places.jpg http://www.maperformance.com/img/forums/footer.png |
Valvetrain, drivetrain, brakes, fueling...it's all here in the "MAP Package Deals" section of our site!
Finally, a fuel feed line solution for your EVO X! http://www.maperformance.com/products/SPP-040501.jpg This MAP fuel feed line kit replaces your entire factory feed line from the fuel pump housing to the fuel rail with 6an hose. Supplied push-on EFI fittings allow for an easy installation that requires no modification to your fuel pump housing or fuel rail! Why replace your factory fuel feed line? Restrictions in the factory line cause pressure drop from the fuel pump to the rail; depending on the application a fuel pressure reading at the fuel rail might be 5, 10, or even 15psi lower than the fuel pressure at the pump. Take a gander at any fuel pump flow chart and you will find that fuel pumps flow significantly less at higher fuel pressures. To put this into perspective a Walbro 400lph fuel pump flows roughly 253lph at 90psi (13.5 volts) in comparison to 300lph when pressure is reduced to 75psi. An additional 50lph translates into almost 100whp of additional fuel capacity on E85! This kit is available with or without a FueLab inline filter, however, please keep in mind that any aftermarket fuel pump (outside of the DW65C) will eliminate your factory in tank filter making this a pretty good idea. |
Did you know that ALL MAP Fab in house manifolds are built with the following features?: 100 Percent polished schedule 10: MAP invested hundreds of hours into developing a system to polish schedule 10 to our specification including research into the best possible tumbler, sampling a wide array of aggregate to generate the perfect finish to start with. All manifolds welded on back purge stations ALL MAP in house fabricated manifolds are tig welded and 100 percent back purged. This a process by which shielding gas is introduced to the interior of the welded area to prevent the molten metal from being exposed to oxygen. This results in stronger, more uniform and cleaner welds. All MAP in house fabricated manifolds come with thick, laser cut/cnc'ed stainless flanges Resulting in longer lasting and more aesthetically pleasing parts All MAP in house fabricated manifolds come ported Where some companies will simply grind away excess material for a simple transition into the runners, MAP manifolds are actually ported and shaped for maximum flow. All MAP manifolds are backed by our Lifetime Ownership Guarantee! When purchasing a MAP manifold, purchase with confidence. We guarantee that manifold for the lifetime of your ownership of it (valid for the original purchaser only). http://parts.maperformance.com/thumb..._EVOX-T3Kh.jpg MAP Complete T3 Turbo Kit (Mitsubishi Evo X) The wait is finally over as you can now get the MAP treatment in a T3 configuration using some of the best components available! Choose from four killer PTE turbochargers (please don't hesitate to contact us for suggestions) and turn your horsepower dreams into a reality. This kit includes every component you will need to complete the installation. Included Components Turbocharger of your choice 3" Stainless Steel V-Band Downpipe with Flex 304SS Tubular Exhaust Manifold with CNC Transition Head Flange to 1.5" Primaries Cam Angle Sensor Heat Shields (not pictured) Turbosmart Comp Gate 40 Wastegate Wastegate Dump Tube Stainless Steel Upper Intercooler Pipe Oil Feed and Return Lines All Applicable Gaskets, Hardware, Clamps and Couplers |
MAPerformance - Your source for everything Turbosmart Wastegates, Blow off valves, boost controllers...Turbosmart has your boost needs under control http://www.maperformance.com/rehost/6422.jpg |
MAPerformance stock frame turbos! Available for the EVO 8/9 (EVO 8 will require a conversion kit to fit an EVO 9 turbo available through us as well!) AND EVO X! Power, reliability, affordability all in a stock frame turbo? It's as simple as that. MAP turbos use our MAP Billet wheel, dual oiling ports for improved lubrication and all EF3, EF4's include upgraded thrust bearings. Simply put, MAP is your answer for your stock frame turbo needs! http://www.maperformance.com/products/map_EVO-EF4a.jpg http://www.maperformance.com/img/guarantee.jpg Customer satisfaction is our highest priority! If for some reason you are not happy with your MAP turbocharger simply send it back to us within 30 days from the date of purchase and we will refund you 100% of your purchase price for that item. Please note the turbocharger must not be damaged or altered in any way, and all accessories must be included within the return shipment. |
AEM High Flow In-Tank Fuel Pump http://www.maperformance.com/products/aem_50-1000.jpg The AEM High Flow Fuel Pump flows 320 lph (84 gph) at 43 PSI and is capable of supporting over 1,000 HP at 43 PSI.* The AEM High Flow Fuel Pump is designed for in-tank mounting for use with gasoline and features a compact 39mm diameter that fits most applications. It has an offset inlet design that eases installations and includes a wiring harness, pre filter, internal fuel hose and clamps, end cap and rubber buffer sleeve. Every pump is tested to flow 320 lph at 43 PSI. AEM High Flow Fuel Pump Features Designed for high output naturally aspirated and forced induction EFI vehicles In tank design Tested to flow 320 lph @ 43 PSI 39mm diameter fits most applications Offset inlet design eases installation Each pump individually tested For gasoline vehicles Kit includes fuel pump, rubber sleeve and end caps, pre filter, hose, clamps and flying lead |
MAPerformance - YOUR resource for the best pricing around on Competition Clutch AND ALL clutch solutions. Competition Clutch specializes in manufacturing sport compact assemblies from street driven to full race applications. You will find our products being proudly used in some of the fastest sport compact race cars in the country, including a number of the most recognized industry icon vehicles. Competition Clutch, featuring their all new Stage 3 Segmented Ceramic Clutch Kit http://www.maperformance.com/product...600-series.jpg This segmented Ceramic material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. This segmented Ceramic material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. |
Did you know that MAP has a package deal section on our website for many of the vehicles we specialize in? That's right, NOW you can get package discounts on brake kits, clutches, headgasket/ head service parts, engine internals, fuel supply components 24/7 simply by surfing the site! Select the car below to be taken directly to the package deal section for your vehicle: EVO 8/9 http://www.maperformance.com/images/C/car-evo8.jpg EVO X http://www.maperformance.com/images/C/car-evox.jpg Where you will find package deals like: https://www.maperformance.com/image....&ts=1240088992 https://www.maperformance.com/image....&ts=1325972695 https://www.maperformance.com/image....&ts=1319828008 AND MORE! |
MAPerformance is proud to offer everything Stance for all your coilover needs! http://www.stance-usa.com/sus/images...ils/GR+-lg.jpg Super Sport http://stance-usa.com/sus/images/sto...supersport.png Super Sport is our main flagship line of coilovers. Featuring an industry leading oversized casing with inverted monotube technology standard, Super Sport dampers have a higher oil capacity and larger piston diameter resulting in access to a wide range of adjustment for ultimate response without compromise. Drivers of all levels can easily adjust the damping for a sport-tuned yet comfortable ride on the street and are able to quickly dial in a more aggressive setting for characteristics needed at the track. Utilizing the very same technology found in top tier racing, Stance Suspension development of the Super Sport coilover answers the demand for a true high performance suspension able to conquer the challenging dynamics of the street. The days of sacrificing ride quality for performance are over! Super Sport+ http://stance-usa.com/sus/images/sto...upersport+.png Super Sport+ coilover has all the features of the Super Sport+ but adds the benefit of a helper spring. The helper spring allows the shock piston to be placed in the optimal position within the shock body, increasing rebound stroke, and maximizing articulation on cars with minimum suspension travel. Pro Comp http://stance-usa.com/sus/images/sto...el/procomp.png Pro Comp is our top of the line single way adjustable coilover. Pro Compfeatures industry leading large 60mm OD casing, which reduces rod pressure for consistent performance.The newly desgined "sensing" piston responsds with full damping capability within as little as 2mm of shaft movement. Instant reaction to changing road surface equals traction and comfort. Pro Comp features inverted monotube (strut type) construction for consistent valving and to withstand high lateral forces of racing. Swift springs are made from H5S.TW which is stronger than regular silicone chrome material. Stronger materials allows for less coils, which makes them lighter, more consistent, and offer more stroke than any other springs brands. Pro Comp features double reinforced lower bracket (strut type) to ensure minimal deflections during high lateral cornering. XR is a no compromise high performance coilover for those who seek the ease of single adjustable valving. Pro Comp 2 http://stance-usa.com/sus/images/sto...l/procomp2.png Pro Comp2 is our top of the line coilover. The Pro Comp2 features 2-way adjustability, enabling the driver to fine tune compression separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control. Pro Comp 3 http://stance-usa.com/sus/images/sto...l/procomp3.png Pro Comp 3 is our top of the line coilover. The Pro Comp 3 features 3-way adjustability, enabling the driver to fine tune low-speed and high-speed bump separately from rebound. An external reservoir is connected to the damper using specially designed fittings that allow the line to swivel and disconnect for packaging and servicing convenience. An optional tool is also available to adjust the gas pressure to give the driver the ultimate adjustment control. We carry many different lines of coilovers and suspension upgrades so don't hesitate to ask for you are looking for anything else! |
