Timing Belt Kits Available @ Boostin Performance
Keep your engine running strong by ensuring you're on top of your maintenance routine. Over time, timing chains wear out, causing the crankshaft to lose sync with the camshaft and the valves. If timing components break, it can severely damage your engine, becoming an extremely costly repair! Save yourself the headache and ensure that your engine will be running properly with a Boostin Performance Timing Belt Kit! When you purchase a BP Timing Belt Package, you'll save on both parts and labor {thumbup} Our Timing Belt Package Includes: - Replacement of Timing Chain: http://shop.boostinperformance.com/p...timingevox.htm - Replacement of Timing Chain Tensioner: http://shop.boostinperformance.com/p...xtensioner.htm - Replacement of Oil Pump Chain: http://shop.boostinperformance.com/p...pump-chain.htm - Replacement of Water Pump (OEM Mitsubishi & Gates Options Available)
- Coolant Flush While your vehicle is here, ask us about our other maintenance services: - Drivetrain Fluid Flushes - Oil Filter & Oil Change - Brake & Rotor Replacement - Clutch Installation & Flywheel Resurfacing - Injector Cleaning Services |
Boostin Bump!
Ttt!
Ttt!
