JIC FLT-TAR EVO X In Stock!!!!
Girodisc Brake Special / JIC FLT-TAR EVO X In Stock!!!! Open Box specials!!
The Girodisc system is a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
The central hat section of the disc is made from 6061-T6 aircraft specification aluminum. The disc is made from cast iron to the same specification and material as used by professional racing organizations. It is a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 10 high strength alloy steel drive pins, manufactured by Girodisc to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
MSRP 700 FRONT AND 800 REARS
PM US FOR PRICING!!
Hey,
I am just picking up the first batch of JIC FLT-TAR's to hit the US over the weekend. We are blowing these out at unbeatable prices, please PM me for pricing and shipping info. MSRP: $2,280, but we are offering them at rock bottom prices!!! We have one set that are open box special, opened to put on display.
Be aware that these are the newest systems from JIC and there is a differance between the A2's and the new TAR's.
The JIC FLT-TAR is the flagship coilover system. All FLT-TAR coilovers are designed on US-spec vehicles for US streets, fitment and performance is unmatched. Included in the kits are pillow ball upper mounts with adjustable camber plates. For flexibility, the dampers have 15-way compression and rebound adjustability. The spring rates are of the linear-rate type with independent ride height adjustable lower brackets. This allows adjustment without compromising damper compression or rebound travel. Based off of racing technology, the FLT-TAR is a street performance suspension, customizable for full time track use. NOTE: some applications may come with a rubber bushing upper mount. A Pillow Ball upper mount may be substituted for additional cost and with no warranty. Please contact us for applications and details.
PM US FOR PRICING!!
Hey,
We are offering a KW variant 3 Special Pricing Program for the Evo X, going on right now. As low as we are going, they are priced to MOVE!!!
"Variant 3 race technology for the road with adjustable compression and rebound damping
The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers"
$1875 shipped!!!!
PM or call us to order today!
$1875 shipped!!!!
SlickCT9A
Aug 24, 2009 10:08 AM
DrivelineSales
EvoX 'For Sale' Suspension / Brakes / Handling
30
Mar 27, 2009 09:30 PM
downforceinc
Evo 'For Sale' Suspension / Brakes / Handling
18
Jan 5, 2009 11:34 AM
evo8dustu
Dec 18, 2008 09:40 PM
Spun Autosports
53
Nov 29, 2008 04:27 AM
