T1r b52 adustable coilover suspension has arrived and is ready to ship!!
Hi Everyone,
Our T1R B52 (52mm Shock Body) Coilovers are here, in stock, and ready to ship!
Specs are as follows:
Comfort and performance normally is not a combination you can find from most of the suspension available on the market. The T1R B52 Coilover Suspension features:
The stock rear upper mount locations where a standard adjust knob will not work as you will not be able to place your fingers into that location for stiffness adjustment. T1R has included the rear damper adjustment knob extenders aid in clearance and offer ease of suspension tuning from the inside of the vehicle.
Introductory special is 20% off MSRP! And with the strong US dollar, it's never been a better time to buy T1R products from Canada!
At the current exchange rate, you can get an approximate US$ price by dividing the Canadian dollar price by 1.2. For instance, CA$1000, divide by 1.2 is US$833!
Here they are!
Full Suspension Kit
Fronts
Rears & Extenders
Front Upper Mount Bottom View
Front Upper Mount Top View / Camber Adjusters
Rears with Extenders installed
- 46mm piston, monotube damper design for maximum dampening range for street and track
- front camber adjustment
- 24 way compression/rebound adjustment (front)
- 32 way compression/rebound adjustment (rear)
- ride height/stroke adjustment
- adjustable spring preload
- SAE9254 cold formed springs
- Made from CNC machined chromoly steel for superior heat dissipation and reduction of unsprung weight
- Front pillowball uppermounts
- Adjusting wrench
- Rear damper adjustment knob extenders.
- Spring Rates: Front 8K; Rear 6K
Here they are!
Full Suspension Kit
Fronts
Rears & Extenders
dD Spikey
Sep 30, 2008 03:43 PM
DrivenConcepts
Evo 'For Sale' Suspension / Brakes / Handling
47
Aug 7, 2006 08:30 PM
