Tein|Hawk|DBA|whiteline|Eibach|Greddy|Perrin
http://www.erzperformance.com
08-10 Evolution X Tein Lowering Springs
Tein S. Tech linear rate springs for the 08-10 Evolution X offer an approximate two inch drop for a more aggressive appearance and better handling. All Tein springs come with a 1 year manufacturer's limited warranty for any applicable manufacturing defects.
08-10 Evolution X GSR Eibach Pro-Kit Springs
The Eibach Pro-Kit for the 2008-2010 Evolution X GSR will greatly improve handling while creating a moderate drop that is perfect for your daily driven Evo X GSR. The reduced wheel gap will make your 08-10 Evo X GSR look the way it should have come from the factory, and the lower center of gravity dramatically helps in the corners. The Eibach Pro-Kit features a progressive spring rate design for the ultimate mix of comfort and performance.
* Ride Height:
* F: -1.2" / R: -1.0"
* FITMENT:
* Mitsubishi Evolution X GSR 2008-2010 (DOES NOT FIT MR)
* Ride Height:
* FITMENT:
Perrin 25mm Rear Sway Bar for 08-10 Evolution X
The Perrin Performance 25mm rear sway bar will keep your 08-10 Evolution X from leaning and rolling through turns, firming up the rear suspension and providing better tire contact and grip through over twisty roads. Built from solid steel, the Perrin Performance rear sway bar comes powder coated red for the ultimate in both strength and durability. Evo owners can choose from three separate mounting positions for a 125%, 153% or 186% increase in rear end rigidity over the stock, 23mm sway bar. Perrin also includes mounting brackets, custom spiral cut urethane bushings designed to eliminate noise and minimize regreasing.
* FITMENT:
* Mitsubishi Evolution X 2008-2010
08-10 Evolution X Whiteline Sway Bars
Ask any racer, any REAL racer, and they will tell you that the best bang for the buck handling mod you can give your Evo X is a high-performance sway bar. So with over 40 years of automotive sway bar and suspension design, you know you can trust your Evo to the experts at Whiteline. As a brand, Whiteline adheres to a strict 'no bling' policy when developing their products, meaning you won't find a wide array of colors or useless cosmetics, just great quality parts and guaranteed performance for your Evo X.
* FITMENT:
08-10 Evolution X Eibach Sway Bars
Reduce body roll and fine tune your 08-10 Evolution X's handling characteristics with Eibach Anti-Roll Kit sway bars. The Eibach front and rear sway bars will increase stability and control while cornering and are one of the best suspension mods you can do to your Evo. Eibach's sway bars are manufactured from cold-formed, high-strength, aircraft-grade steel. You can get the Eibach sway bars as full, front and rear kit or as individual front bar and rear bar kits. Eibach Anti-Roll Kits include all necessary mounting hardware and instructions for easy installation.
* Specifications:
* Front: Adjustable, 29mm
* Rear: Adjustable, 25mm
* FITMENT:
* Specifications:
* FITMENT:
08-10 Evolution X Hotchkis Sway Bars
A Hotchkis sway bar is one of the best upgrades you can do to your car; they not only make a huge improvement with handling, but are affordable one of the most affordable mods out there. Hotchkis designed their massive, 32mm sway bars for the front and the rear. Hotchkis engineers put a lot of research into developing their adjustable sway bars for the Evo X. The front bar is 2-way adjustable from 50% to 70% stiffer than stock. The rear is 3-way adjustable with settings at 155%, 195%, and 245% stiffer than stock. In testing the sway bars have proven effective at reducing body roll and tightening overall handling. If big sway bars are what you are after, you can't go wrong with choosing the Hotchkis say bars for your Evo X!
* Specifications:
* Front: 2-way Adjustable, 32mm
* Rear: 3-way Adjustable, 32mm
* FITMENT:
* Specifications:
* FITMENT:
08-10 Evolution X Whiteline Control Arm Bushings
To get the most control from your 08-10 Mitsubishi Lancer Evolution X, you need to upgrade any factory bushing you can. The Whiteline urethane control arm bushings are stiffer than the soft, rubber OEM bushings and will transmits more feedback from the road, through tires and up to the steering wheel and through the chassis. You will feel more noise, vibration and harshness, but nothing that would prevent your Evo from being daily drivable. Whiteline bushing kits include items shown in pictures plus grease for use during installation.
* FITMENT:
* FITMENT:
08-10 Evolution X Whiteline Roll Center Kit
Lowering the ride height of your 08-10 Evo X is can be a very effective modification, enhancing handling by creating a lower center of gravity and giving the car an aggressive look by minimizing wheel gap. Unfortunately, once the stock ride height has been altered, the front end roll-center changes too, which can make your car handle worse than stock when you are trying to carve out those deep corners. The Mitsubishi Evo X is especially prone to this when lowering springs are installed due to the way stock suspension geometry was designed. In many cases the roll-center is actually moved to below pavement level.
08-10 Mitsubishi Evolution X Brake Pads pm for best price
Hawk Performance Ceramic
Hawk Performance Ceramic brake pads are were developed for those enthusiasts who want to improve stopping power without the annoying side effects sometimes associated with more aggressive pads. Hawk Performance Ceramic pads are engineered with a linear friction profile for maximum performance while reducing NVH (noise, vibration, and harshness) for a smoother ride and ultra-low brake dust accumulation. In addition, you can expect Hawk ceramic brake pads to provide increased pad and rotor life and a more responsive ABS braking system. Hawk Performance Ceramic pads are intended for street use only.
* FITMENT:
Hawk HPS
Hawk HPS (High Performance Street) pads offer a tremendous improvement in braking distance over the Evo's OEM pads. Hawk's unique Ferro-Carbon formula was developed for street performance using the safety and quality of Aerospace and Motorsports severe-duty friction technology. The HPS compound offers a high coefficient of friction and can provide you 20-40% more stopping power and improved resistance to fading over Evolution's OEM replacement pads.
HPS's Ferro-Carbon compound provides your Lancer Evolution increased stopping power, long-life, less dust, and reduced noise compared to other after market performance brake pads. All Hawk Performance products provide a limited lifetime warranty, ensuring products to be free of defects from manufacturer's workmanship and materials. Hawk HPS pads are designed primarily for a daily driven Evo X but will hold up under light autocross duty as well.
* FITMENT:
Hawk HP+
Hawk HP+ pads are made for the Evo X that gets driven to, and on the track. The HP+ offers increased friction over the HPS, at the price of a little more noise (squealing) and more dust. Brake squeal is not uncommon in the HP+ due to the higher temperatures required for their peak friction, but once warmed up, this higher operating temperature will consistently allow your Evo X to brake more quickly, with minimal fade.
These pads are excellent for the occasional HPDE/track day or for the very competitive autocross racer. If your Evo will see more frequent track use, or competition-only applications, consider the Hawk Blue 9012 race compound pads.
* FITMENT:
Project Mu Street: Type NS
Project Mu Type NS brake pads are developed specifically for street use. Guaranteed to outperform OEM pads, Project Mu NS street pads are reliable in any weather or road conditions. NS street pads give outstanding initial stopping power that is of prime importance on the street. Made from an Asbestos-free brake compound, NS street pads also have very minimal dust and very low squeal properties.
* Specs:
* Material: Carbon Ceramic
* Applicable Rotor Temp: 0-400°C
* Friction Coefficient: 0.34-0.43μ
* FITMENT:
* FITMENT:
Hawk HPS
* FITMENT:
Hawk HP+
* FITMENT:
* Specs:
* FITMENT:
The DBA 4000 Series rotor is a mid-level brake rotor that has more than enough performance for any street driven car and will work very well on a weekend track toy or autocrosser. DBA 4000 Series rotors feature Thermal Stability Profiling (TSP) for improved heat handling. TSP enhances the micro-structure of the rotor material providing greater thermal stability. Increasing the thermal stability allows your DBA rotors to take more heat, making them more stable under heavy, frequent braking. DBA rotors with TSP will experience improved brake pad and rotor life.
Thermo-Graphic paint markings on the edge of DBA's 4000 Series rotor change color at specific temperature thresholds allowing you to check your braking performance quickly and easily. Green changes to white at 856°F, orange will change to yellow at 1022°F and the red will change to white after 1166°F. Ideal braking temperatures are between 850°F and 1000°F (so the green will become white and the orange and red are unchanged).
* Notes:
* DBA brake rotors are sold by the PAIR ONLY.
* FITMENT:
StopTech Power Slot Slotted rotors for the 08-10 Evo X help reduce brake fade by releasing the boundary layer of gases that can build up between the pad and rotor surface and, consequently, inhibit performance. This is how Power Slot rotors make a big difference in your Subaru's braking performance: The exclusive StopTech Power Slot Vac-U-Slots machined into the rotor "wipe" brake pads clean, evacuate gases, and shed heat from your rotors to provide fade free braking stop after stop.
StopTech Power Slot Plus rotors are manufactured to the highest tolerances of safety and quality. Slotting, unlike drilling, will not compromise the structural integrity of the rotor; drilling weakens a rotor and may cause stress points that can lead to cracking and failure. Drilled rotors also lose considerable surface area compared to slotted rotors, which means a smaller surface area for pad-to-rotor contact. StopTech Power Slot rotors are designed using the highest quality OEM replacement blanks. All machining is done in-house to StopTech Power Slot's application specific tolerances to ensure optimum quality control. The final touch is a military-spec cadmium plating that gives StopTech Power Slot rotors their bright silver finish and protects the rotor from debris. This eliminates 'rusty rotor syndrome' and enhances the look of custom wheels.
* Notes:
* StopTech Power Slot brake rotors are sold by the PAIR ONLY.
* Notes:
* FITMENT:
* Notes:
08-10 Evolution X Techna-Fit Brake Lines
Techna-Fit Stainless steel brake lines are a great way to improve the performance and safety of your 08-10 Evo X. Braided stainless steel brake lines eliminate the ballooning associated with OEM rubber lines and are more resistant to puncture or collapse. Pedal feel will in your Evo X will also feel more responsive and firm. All Techna-Fit stainless steel brake lines are assembled to exact D.O.T. specifications and include all necessary fittings and hardware for a direct bolt-on installation.
* FITMENT:
* FITMENT:
