Stay Planted -- Tried and Tested Suspension Parts // DSG Performance
[CENTER]
Having personally tried MANY different setups and after listening to the feedback from MANY customers, we have compiled what we think is the best daily/occasional track setup for the X. While some of you may have a few of these parts already, it's definitely worth your while to complete and really change the dynamic of the car into an absolute beast-mode X.
Included in this list are our famous DSG Edition Coilovers, there is virtually nothing on the market for the X that is as complete of a coilover -- combined with the amazing Fortune Auto warranty. We also designed these on our X which feature the entire Whiteline line-up that's listed here so we can guarantee the results!
______________________________
DSG Edition Fortune Auto 500 Series Coilovers
$1,719.99
(shipped anywhere in the lower 48)
Daily driving, ride quality, handling, getaroundthetrackasfastasyoucan - Evo X owners want it all. We want our cars to perform like they're full blown race setups but we cringe at the thought of being uncomfortable on the daily drive to work on what are usually (lets face it) shoddy city roads. We want comfort, but we want performance.
The DSG Edition 500 Series Coilovers have been put together for the daily driver/weekend warrior to be the ideal street and track use coilover setup. We have built these with great consideration to our customers feedback for the perfect blend of comfort and performance, something you can use on a daily basis and still kick it at the track. By blending Fortune's top available upgrades, higher quality oils, tested spring rates & throwing in a bit of DSG attitude - this is a perfect bolt on balanced solution for the average Evo owner. I've installed and tested these on my own Evo X and boys, they are fantastic. Comfortable with a point and go attitude. They completely transformed how my car reacts and feels. I can easily say, these are by far my favorite mod I've done to the car thus far in terms of handling vs power.
Every DSG LIMITED Edition 500 Series Coil gets the same treatment as Fortune's top of the line leading Dreadnought series. Hand assembled and inspected, each package comes with a signed Certificate of Assembly & Shock Dyno Sheet.
As with ALL Fortune Auto Coilovers, these will be hand assembled and shipped upon completion. Fortune requires roughly 2-4 weeks for total processing and assembly.
9k Front / 9k Rear Balanced Spring Rates:
Despite the popularity of stiffer rear springs with many manufacturers, the Evo X suspension setup is optimized for a balanced front to rear ratio's. This allows the customer to really fine tune their driving style and setup, by installing a rear sway bar you can effectively raise the rates in the rear if so desired. With the ability to adjust via the way bar, you can change your style for on and off track days. We chose a 9k / 9k spring rate as we find it to be the perfect blend of stiff vs soft. Comfortable on the road without jarring the passengers, but tight enough to handle the sharpest of turns.
Swift Springs Standard:
Because they kick ***. Swift Springs are some of the best springs in the entire world, by including them with the coilovers you are essentially upgrading every aspect of the setup. Adding comfort, compliance and reduced noise and weight.
Upgraded AMSoil Synthetic Shock Oil Standard:
We added upgraded AMSOIL Synthetic Fluid normally reserved for the Dreadnaught line of Coils which significantly limits shock fade and inconsistent dampening, providing a drastically smoother function. Constant friction in a shock body decreases suspension performance while causing scuffing and wear on the inner walls. AMSOIL Suspension Fluid contains friction modifiers to reduce frictional energy loss and heat buildup. Anti-wear agents protect against premature scuffing and wear, while maintaining proper suspension absorption.
Radial Bearings Standard:
Radial Bearings are designed to reduce unwanted noises often associated with aftermarket coilovers such as "Clunks" & "Twangs". No one who is daily driving wants to have embarrassing noises coming from their car, bothering you and being embarrassing. Its like squeaky brake syndrome. You have brembo's, not poor quality brakes but with OEM pads they can turn heads at low speeds. Not in the good way. Radial Bearings put and end to coilover noise.
Rear Helper Adjusters FREE:
Included free with all DSG Edition 500's, Rear Adjusters are designed to allow you to remotely adjust your rear dampening. Due to confined space, adjusting the rear dampening can be a bit of a pain. These allow for a clean install for those who wish to retain their trunk lining and plastic "guard" for the battery area. You simply install these to the coils and run them right over the plastic so they are cleanly left in the trunk compartment. Turn the dial, adjust the dampening!
Whiteline Essentials
The Stay Planted package can't be complete without the right suspension components. That's where Whiteline comes in. The components below is what we suggest to really take your vehicle's dynamic to the next level.
Whiteline Front/Rear Sway Bar & End Link Combo
Whiteline Sway Bar Lateral Locks
Whiteline Camber Toe Arm
Whiteline Correction Assembly
$1,719.99
Whiteline Front and Rear Sway Bars/End Link Kit - EvoX (BMK010)
Whiteline 27mm Sway Bar Lateral Locks - EvoX (KLL127)
$649.99
This is a new release from Whiteline combining both front and rear 27mm sway bars while including the front and rear end links. We almost always sold these together but they've made a nice simple new part combining both of these. Sway bars are one of the best upgrades you'll ever do on the X. Keeping it planted and neutral will totally give you the feedback you need for "spirited" driving and track days!
As an extra, we are also including the lateral locks that prevent the sway bar from moving (27mm KLL127)
$649.99
Like the title states, for the entire month of September Fortune Auto is offering a main-in $150 cash-back on any coilovers purchased. Let us get some amazing Fortune Auto coilovers on your car, take advantage of our financing option
(cash back applies to DSG Editions also )
Black Friday is here and we're offering an AMAZING special on Fortune Auto coilovers. From Black Friday to December 25th, get their new piston cup kit with FREE shipping and a FREE $250 upgrade to DSG Editions.
Pair that up with our bonus offer during this time, using our Affirm financing program get 0% interest financing for 6-month terms:
Do Work Son
Mar 3, 2017 11:08 PM
DSG Performance
EvoX 'For Sale' Exterior Styling
23
Apr 24, 2015 01:32 PM
Kami Speed
Evo 'For Sale' Suspension / Brakes / Handling
50
Mar 7, 2008 04:22 PM
