GTX-R in its native enviroment
So far the new combo is up about 11% or so at 35psi (which is lower boost). Was high 500s low 600s with the slicks on (burn out on the dyno so it soaks up the power) last season with the 8.5:1 standard 4202 and with the 10.5:1 GTX-R its at 669whp (35psi). For what its worth the car runs 9.29@150 with 611whp (around 40psi previously) when dyno'd that way.
We'll get some street tires back on and get some proper numbers later. Last year we saw 814 @ 44psi through the auto and around 720whp or so at 35 on street tires. Time didnt allow for all the tire switching as the car is racing in Sacramento tomorrow.
so far the new combo is up about 11% or so at 35psi (which is lower boost). Was high 500s low 600s with the slicks on (burn out on the dyno so it soaks up the power) last season with the 8.5:1 standard 4202 and with the 10.5:1 gtx-r its at 669whp (35psi). For what its worth the car runs 9.29@150 with 611whp (around 40psi previously) when dyno'd that way.
We'll get some street tires back on and get some proper numbers later. Last year we saw 814 @ 44psi through the auto and around 720whp or so at 35 on street tires. Time didnt allow for all the tire switching as the car is racing in sacramento tomorrow.
9.3@153ish at 37psi... up 3mph and 3psi less caompared to the 9.29@149.65 at BOTI. We think the tranny might be going away as this was on the backup tranny and it wasnt feeling like the normal main operations tranny. The car ran mid 152 at 35psi as well but at 9.6 with a fairly soft launch. It was waiting to shift like it didnt have enough line pressure to force the shift.
Jeff says it scares him now. I think that means pretty awesome.
I think we had the usual 32psi spike, but it was holding more than the 25psi at 9k than the MAF tune. I think its holding right around 30psi, but its been a while. You should have the graph at the shop.
That turbo is beastly!
