Effects of E-85
Old Jun 29, 2006 | 09:07 AM
  #31
MalibuJack's Avatar
I'm really looking forward to the opportunity to run E85.. Its sad that conversions are falling into the laws that govern "Tampering", but if it becomes available, my car will be running it more than the few simple experiments I had tried in the past..
Old Jul 4, 2006 | 03:12 PM
  #32
Flyin EVO 2's Avatar
If your going to start to try and monkey around with e85 here are five rules of thumb.
#1) You must have fuel control
#2) You must have a wide band start at 10.5 to 1 then work towards 11.2
#3) You must have a decent amount of room left in your injectors to richen it up
#4) Before you start making pulls richen it up by 25% vs 93 octane settings.
#5) At first try a 30% e85/ 70% 93 mix. This will give you a 96 octane, won't be harmfull to seals and such, and will still have a close weight to gas so it won't need as much injector.
Old Jul 5, 2006 | 04:22 PM
  #33
KazzEvo8's Avatar
So ... e85 mixed with 93 will yield higher octane by default or am I better off mixing 100 octane with 93 as I do now???
Thanks.
Old Jul 5, 2006 | 04:28 PM
  #34
Ludikraut's Avatar
Thanks.
Unless you plan on retuning, you're better off with what you are doing now.
l8r)
Old Jul 9, 2006 | 06:57 AM
  #35
E85 is actualy 105 octane, but if you don' t have a wide-band, or aren't keen on tuning I second Ludikraut's post. Because it's so much lighter of a fuel you can't just dump it in without re-tuning it.
Old Jul 9, 2006 | 07:24 AM
  #36
MalibuJack's Avatar
I actually have 1000cc injectors with a Stock ECU and GT35r turbo.. The stock ECU injector drivers mean I can run 780-880cc injectors, but I chose to go with 1000's with the expectation of running E85 in the next few years.. Now with ECUFlash capabilities, it makes perfect sense that someone with access to E85 to try it.. No word up here in the Northeast, and the only E85 up here is either what I had brought in to test on my honda a few years back, and some government sites have been testing it.
Old Jul 9, 2006 | 07:35 AM
  #37
EvoG8r's Avatar
I know 2 people that are running a mix of 15-20% E85 right now. One is on stock turbo and the other is a 60 trim with 880s. The second one adjusted his tune while the stock turbo did not. He did say that his gas mileage went down.
Old Jul 9, 2006 | 08:44 AM
  #38
donour's Avatar
Yes mileage will go down significantly because E85 has a lower energy content per volume than gasoline. You simply must inject more fuel under all conditions.
d
Old Jul 9, 2006 | 02:59 PM
  #39
SaabTuner's Avatar
Originally Posted by Fourdoor
Since the Alcohol blend burns cooler than pure gasoline your exhaust temps are significantly lower (yes, this WILL affect spool up on a turbo)
But, as hotrod points out in the NASIOC thread, the exhaust volume for a specific airflow rate is higher. He found the spool-up had almost no noticable difference.
Due to the emissions issues, it is illegal to convert over to E-85. For most people here, that means treat it just like running without a cat, it is illegal and carrys a huge fine..... but you are very unlikely to be caught. Do at your own risk!
Keith
Mostly evaporative emissions, IIRC. It's probably possible to get a conversion kit CARB approved, but it's more difficult than for other parts because you have to deal with the gas tank and charcoal cannister.
I also have a feeling that it will be hard for either a police officer, or an emissions station, to notice the larger injectors on an E85-powered vehicle. Whereas running without a cat is generally quite obvious. hah
-Adrian
Old Jul 9, 2006 | 04:37 PM
  #40
rraulston's Avatar
In Tucson, There is an EVO converted to E-85. He has the Apex turbo kit and 880cc injectors. Tuning stopped at i think 25 PSI and 420HP due to 100% duty cycle. The Tuner does Mustangs with 1000HP e-85 motors with AEM's. He says under normal driving, you consume 15% more fuel and under high boost as much as 40% more fuel. He told me to get 1000cc injectors and he would re-tune me and save me a grip of money on the Super gt-plus Sunoco i buy......I was on the verge of doing it, but my ignition wont stay steady past 26psi.......
Old Jul 9, 2006 | 09:29 PM
  #41
machron1's Avatar
Gap your plugs a bit closer...
Old Jul 9, 2006 | 11:26 PM
  #42
EVO8 WHOA's Avatar
mine are .018 and it runs fine i am usin a big methanol shot daily too and 25psi daily car Al did the tune.. just fyi
Old Jul 18, 2006 | 06:08 AM
  #43
JrCRXHF's Avatar
I have been running E85 in my honda now for 3 years it works great with the turbo.
Old Aug 22, 2006 | 01:17 AM
  #44
toledodsmr's Avatar
A lot of people are getting licensed to make their own stills and manufacture their own fuel. I personally love the idea. What other fuel can u get drunk off of???
Old Aug 22, 2006 | 04:55 AM
  #45
SaabTuner's Avatar
Bad grammar! Never end sentences in prepositions! (kidding kidding!)
I'd love to get drunk on the same chemical that powers my car. Gotta love multi-purpose fuels!
