Setup of Power FC
Old Nov 23, 2004 | 11:33 PM
Dynofrk666's Avatar
Setup of Power FC
On a level from 1-10 (1 being easiest 10 being hardest) about how hard is it to install the power fc and get the car to run properly for someone who isnt a pro at tuning. Also can a vta bov be used with the d-jetro power fc (the one that replaces the maf with a map sensor) I was either going to get the power FC or the turboxs UTEC...just seeing which one would be easier/more efficant
Old Nov 24, 2004 | 02:46 PM
Karash's Avatar
if you are running map, then VTA is fine.
I really cant comment on how hard it is to tune. It is very very easy to change each point in the map however. It also has a test mode that resets once the key turns off for testing.
Old Dec 22, 2004 | 03:27 PM
Guru's Avatar
The D Jetro model is pretty good. I've had great luck with it but the install is tricky and if you do not have a shop who has experience with it, it could be a problem.
